C2G 7m Cat5E 350 MHz Snagless Patch Cable - Yellow
Quicklinx: 6BMSWS00 Mfr#: 83246
For Fast Ethernet networks that require bandwidth-intensive voice, data, or video distribution applications. Meets all Cat5e TIA/EIA standards, and drastically reduces both impedance and structural return loss (SRL). Each of the individual pairs are bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality copper cable, this design minimizes Near-End Crosstalk (NEXT) levels. The molded, snagless boot prevents unwanted cable snags during installation and provides extra strain relief.
  • Enhanced connectivity
    The Cat5e Booted Unshielded (UTP) Network Patch Cable by C2G ensures a reliable connection with its high-quality, gold-plated RJ-45 connectors. These connectors provide a secure link between devices, minimizing interference and maximizing signal quality for optimal network performance.
  • Durable design
    Featuring a robust PVC jacket and an American Wire Gauge (AWG) of 24, this patch cable is designed for durability and long-term use. Its construction is ideal for both commercial and residential applications, providing a dependable solution for your networking needs.
  • High-speed performance
    Tested to support frequencies up to 350 MHz, this network patch cable is capable of delivering high-speed data transmission. It's perfect for supporting the bandwidth requirements of both current and future network applications, ensuring your setup is ready for anything.
C2G Cat5e Booted Unshielded (UTP) Network Patch Cable - patch cable - 7 m - yellow
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded, snagless, stranded
Length
7 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Yellow
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Length
7 m
Yellow
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
