Share a USB device among four PCs or quickly extend the number of USB devices shared by using a USB hub to daisy-chain up to 127 devices. Hot key functionality enables use of a keyboard to switch among computers while the LED port status indicator shows which computer is selected. Plug and Play functionality makes installation a breeze.
- C2G 4-Port USB 2.0 Manual Switch - USB peripheral sharing switch - 4 ports
- Subtype
- USB
- Ports
- 4 x USB 2.0
- 7.6 cm x 10.2 cm x 2.5 cm
- 263 g
- Blue
- System Requirements
- Microsoft Windows 98SE/2000/ME/XP
- 1-year warranty
- Enclosure Type
- Desktop
- Subtype
- USB
- Ports
- 4 x USB 2.0
- 4 x USB 2.0 Type B , 1 x USB 2.0 Type A
- Blue
- OS Required
- 7.6 cm
- 10.2 cm
- 2.5 cm
- 263 g
- Limited warranty - 1 year
