C2G 3m RapidRun® CL2-Rated Desktop PC Runner Cable
Quicklinx: 6C3QWS00 Mfr#: 87000
Imagine a VGA cable you can pull through 30 mm conduit with no soldering of the HD15 connector! Or having the option of switching the installed cable from VGA to Component Video with audio in less than a minute! With RapidRun, you can easily do this and more. No cabling solution on the market will do more to make your installations easier or more versatile!
RapidRun's revolutionary design provides the greatest flexibility and ease of installation without loss of signal quality. Three styles of Runner base cables, 3-coax with 4 twisted-pairs, 5-coax and HDMI/DVI, allow this unique cable system to be configured for UXGA, component video, composite video, digital/analog audio and/or digital audio/video signals.
C2G RapidRun PC/Video UXGA Runner Cable - video / audio cable - 3 m
Cable
Video / audio cable
Coaxial
American Wire Gauge (AWG)
28
Length
3 m
Connector
MUVI connector - female
Connector (Second End)
Colour-coded connectors, Class 2 rated
Cable Type
Video / audio cable
Coaxial
28
Jacket Material
PVC
Shielding Material
Foil with copper braid
Impedance
75 Ohm
Length
3 m
Connector
Connector cap
RoHS
