C2G 35ft Ultra Flexible 4K Active HDMI w/ Ethernet Cable Gripping 4K 60Hz - In-Wall M/M
Quicklinx: GRR3WS00 Mfr#: C2G10383
Length: 10.7m
£90.80 ex VAT
£108.96 inc VAT
The C2G Performance Series Ultra Flexible Active High Speed HDMI Cable is perfect for connecting a wide variety of devices from computers to projectors and monitors, AV presentation furniture, or in-wall applications requiring high speed HDMI features and video resolutions up to 4k (4096 x 2160) at 60Hz - perfect for conference rooms, classrooms, churches, and other commercial installations.
This Ultra Flexible Active High Speed HDMI Cable was designed for installations in tight spaces and offers commercial grade connectors that feature compact overmolding for high density environments, integrated finger grips on the top, bottom, and sides, for easy insertion and removal, and the gripping connector shell has 2x greater port retention to keep your devices connected. The gold plated connectors on the cable allow for better shielding, increased electrical conductivity, and durability.
This Ultra Flexible Active High Speed HDMI Cable amplifies the signal from the source and sends it longer distances without degrading that signal. Active HDMI cables can only run in one direction - connect the source end to the source and the display end to your display. The connectors are conveniently labeled for source and display, so there is no confusion with this directional cable. The source connector end even has a tag on the cable as an extra reminder.
This Ultra Flexible Active High Speed HDMI Cable supports the updated library of Consumer Electronic Control (CEC) commands, allowing communication between devices connected through the HDMI ports. Lastly, this fully-functional, high bandwidth cable has been tested to perform at industry standards and is backed by a lifetime warranty.
  • Colour
  • Connector 1
    (1) HDMI Male
  • Connector 2
    (1) HDMI Male
  • Warranty
    Lifetime
C2G 35ft Ultra Flexible 4K Active HDMI Cable Gripping 4K 60Hz - In-Wall M/M - HDMI cable with Ethernet - 10.7 m
Cable
Max Output Resolution
4096 x 2160 - 60 Hz
Length
10.7 m
Connector
HDMI - male
Connector (Second End)
HDMI - male
Active cable, 4K60Hz support
Cable Type
HDMI cable with Ethernet active, 4K60Hz support
Jacket Material
PVC
Length
10.7 m
Plated Connector
Gold
Dolby TrueHD support, Dolby DTS-HD Master Audio support, HDR support, Hybrid Log-Gamma (HLG), Dolby DSD Audio, 3D ready
Adapters & Converters
4096 x 2160
Refresh Rate
60 Hz
Connector
19 pin HDMI Type A - male
CEC CMG FT4
454 g
Limited warranty - lifetime
Length: 10.7m
Brand: C2G
