Replace your overused or misplaced power cable, or just get some extra cords for convenience. This power cord is designed to work with laptops that use a 3-slot power cord. This 18 AWG cord features a fully moulded design for maximum durability and long life. The female connector, often called a Clover Leaf connector, plugs directly into the device while the male connector plugs into a standard outlet.
Product Use
UK replacement power cord for many laptops -
Warranty Details
This product carries a lifetime warranty -
Connector Information
The female connector is often called a Clover Leaf connector
- C2G Laptop Power Cord - power cable - IEC 60320 C5 to BS 1363 - 2 m
- Power cable
- Molded
- Length
- 2 m
- Localisation
- United Kingdom
- Connector
- Power IEC 60320 C5
- Connector (Second End)
- Power BS 1363 - male
- Rated Voltage
- AC 250 V
- Black
- Limited lifetime warranty
- Power cable
- American Wire Gauge (AWG)
- 18
- Rated Voltage
- AC 250 V
- Molded
- Length
- 2 m
- Black
- Localisation
- United Kingdom
- Connector
