C2G 20m SC/ST Duplex 62.5/125 Multimode Fibre Patch Cable - Orange
Quicklinx: 6BYVWS00 Mfr#: 85043
With SC to ST termination, this high-quality fiber optic patch cable is specifically designed for fast ethernet, ATM and gigabit ethernet applications. The small LC connectors satisfy the need for higher port density both in the telecom room and the work area, and offer twice the port density of traditional SC and ST fiber connectors. The LC connector with its RJ-style latch clip design is easy to engage and disengage, and gives each connection greater durability in resisting pulls, strains, snags, and impacts during cabling installs and maintenance. The ST connector features a bayonet locking system.
C2G patch cable - 20 m
Patch cable
Fibre optic
Type of Fibre Optics
Multimode
Molded
Length
20 m
Core / Cladding Diameter
62.5 / 125 micron
Connector
2 x ST multi-mode - male
Connector (Second End)
2 x SC multi-mode - male
Network Cable Type
Patch cable
Fibre optic
Multimode
Fibre Qty
2
62.5 / 125 micron
Molded
Length
20 m
Connector
RoHS
