This adapter converter is an ideal solution for converting the Mini DisplayPort output of a small laptop or tablet so that it may be connected to a computer monitor which accepts a VGA input. This adapter converter carries an analogue video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
- C2G 20cm Mini DisplayPort to VGA Adapter - Thunderbolt to VGA Converter M/F - Black - VGA adapter - 20 cm
- VGA adapter
- Length
- 20 cm
- Connector
- Mini DisplayPort - male
- Connector (Second End)
- HD-15 (VGA) - female
- Black
- 3-year warranty
- VGA adapter
- Length
- 20 cm
- Black
- Connector
- 15 pin HD D-Sub (HD-15) - female
- 3-year warranty
