C2G 15m Cat6 550 MHz Snagless Patch Cable - Yellow
Quicklinx: 6BRFWS00 Mfr#: 83473
For voice/data/video distribution, this cable it will handle bandwidth-intensive applications up to 550 MHz. Meets all Cat6 TIA/EIA-568-B-2.1, draft 9 standards, and drastically reduces both impedance and structural return loss (SRL) when compared to standard 100 MHz wire. Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point.
  • High-quality connectivity
    The Cat6 550MHz Snagless Patch Cable from C2G is designed with a PVC jacket and gold-plated connectors to ensure high-quality, corrosion-resistant connectivity for reliable data transmission.
  • Enhanced performance
    With a tested frequency of up to 550 MHz, this patch cable supports high-speed data applications, making it ideal for complex networks and ensuring your connection remains stable and fast.
  • Durable design
    Featuring a snagless design and a durable PVC jacket, this cable is built to withstand rigorous use, making it a dependable choice for both home and office environments.
C2G Cat6 550MHz Snagless Patch Cable - patch cable - 15 m - yellow
Patch cable - CAT 6
Wiring Scheme
T568B
Molded, snagless, stranded
Length
15 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Yellow
Network Cable Type
Patch cable - CAT 6
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Plated Connector
Gold
Length
15 m
Yellow
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 550 MHz
