C2G .5m Cat5E 350 MHz Crossover Patch Cable - Red
Quicklinx: 6BNYWS00 Mfr#: 83331
With a C2G Enhanced CAT5 350MHz Crossover Patch Cable and a network adapter, you can easily network two Windows-based computers in a peer-to-peer networking configuration. In addition, this cable can be used for hub-to-hub, transceiver-to-transceiver or repeater-to-repeater Ethernet connections.
  • High-quality connectivity
    The Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable is designed with 24 AWG wires and a durable PVC jacket, ensuring reliable connectivity and longevity. Its gold-plated connectors provide a secure connection and minimize interference, making it an ideal choice for setting up or extending your network.
  • Enhanced performance
    With a tested frequency of up to 350 MHz, this crossover cable is engineered to support the bandwidth requirements of high-speed data applications, voice, and video. The use of T568B wiring scheme and UTP technology helps in reducing noise and crosstalk, offering a seamless networking experience.
C2G Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable - crossover cable - 50 cm - red
Crossover cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Stranded, uniboot
Length
50 cm
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Red
Network Cable Type
Wiring Scheme
T568B
Jacket Material
PVC
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Plated Connector
Gold
Stranded, uniboot
Length
50 cm
Red
Connector
RJ-45 - male
RJ-45 - male
RoHS - up to 350 MHz
