Buffalo's LinkStation Pro Quad is the ideal solution to keep important files safe! Stream your favorite music and videos directly from the LinkStation Pro Quad to a computer or Logitech Squeezebox, PS3, Xbox 360 or network attached DLNA or UPnP media player or Buffalo LinkTheater. With ultra fast data transfer speeds, the LinkStation Pro Quad is a high performance dual drive that can be configured in RAID 0 for performance or RAID 5 for redundant storage if a hard drive failes, your data is safe. Easy to install, the LinkStation Pro Quad lets you store and share your music, photos, and videos in your home or small office. Access and share your multimedia collection from anywhere at any time using Buffalo's WebAccess, the feature that allows users to easily stream digital content stored on any Buffalo network storage solution from anyway in the world via a Web browser, or using the newly announced free WebAccess app, via an iPhone, iPad, iPod touch or Android SmartPhone. Store, share and save with the Buffalo LinkStation Pro Quad.
Network attached storage
Connect LinkStation Pro Quad to any Ethernet port or to the back of your wireless router and instantly access storage from any computer on the network. Store or back up digital photos, MP3s and documents on one hard drive and access it from any computer simultaneously. -
4-drive raid storage
LinkStation Pro Quad features four hard drives and support for multiple levels of RAID redundancy for a customizable blend of capacity and data protection. -
High speed
Optimized for maximum transfer speed, LinkStation Pro Quad utilizes an upgraded processor and RAM, offering greater than 2X the data transfer speed of competing devices. -
Whole home backup
Five copies of NovaBACKUP Professional for Windows and a built-in Time Machine Server allow for back up of all PCs and Mac computers in your home to a central, always available storage device. Put an end to moving USB drives between multiple computers. -
Shared storage
Store or back up files from multiple PCs, laptops or Mac computers in one central location. -
DLNA CERTIFIED and iTunes servers
Stream content directly to any DLNA compatible media player or use LinkStation Pro Quad as content source from within your iTunes application. -
BitTorrent client
Download digital content over the Internet directly to your LinkStation Pro. -
Two USB 2.0 ports
Attach a printer to the network, add a USB hard drive for additional storage or backup, or connect to a UPS for AC power failure management. -
Time Machine compatibility
Use the LinkStation Pro Quad with time machine backup. -
Eco-minded
With the power savings feature you regulate the power usage of your LinkStation at predetermined times, shutting the unit down and reducing energy consumption. -
TurboPC with turbo copy
Enhance the overall performance of your PC. -
No annual or monthly fees
To use any features or services, including WebAccess with iPhone and iPad support, or to add multiple users and groups. -
Direct copy
Plug in your USB hard drive or camera to quickly offload pictures.
- BUFFALO LinkStation Pro Quad - NAS server - 8 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 8 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 14.9 cm x 23.3 cm x 15.4 cm
- 5.5 kg ()
- Processor
- Marvell 1.6 GHz
- Storage Controller
- RAID SATA 3Gb/s RAID 0, 1, 5, 10, JBOD
- Hard Drive
- 4 x 2 TB SATA 3Gb/s
- Networking
- Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Apple MacOS X 10.4 or later, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 R2, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits)
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 8 TB
- 14.9 cm
- 23.3 cm
- 15.4 cm
- 5.5 kg ()
- Built-in Devices
- Print server
Processor / Memory
- Processors Installed
- Marvell 1.6 GHz
Storage Controller
- RAID
- Interface Type
- SATA 3Gb/s
- Supported Devices
- Hard drive, disk array (RAID)
- RAID Level
- RAID 0, RAID 1, RAID 5, RAID 10, JBOD
Hard Drive
- HDD
- Capacity
- 4 x 2 TB
- Interface Type
- SATA 3Gb/s
- 128-bit AES
- Data Link Protocol
- TCP/IP, NTP, FTP, SMB
- Remote Management Protocol
- HTTP
- Network Services Compatibility
- FTP, Server Message Block (SMB), HTTP
- Print server, iTunes server, FTP server, Buffalo Web Access, BitTorrent Client, Direct Copy
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
- Expansion Bays
- 4 (total) / 0 (free) x external
- 2 x USB 2.0 - Type A , 1 x Ethernet 1000Base-T - RJ-45
- Power Device
- External power adapter
- Voltage Required
- 43 Watt
- Software Included
- NovaBACKUP Workstation - Buffalo Edition (5 licences)
- OS Required
- Limited warranty - 2 years
- 0 °C
- 35 °C
- 20 - 80% (non-condensing)
