TeraStation Pro Rackmount WSS Storage Server provides high performance four hard drive RAID based network storage with the power of a Windows Server operating system. Powered by Microsoft Windows Storage Server 2008 R2 Workgroup Edition, TeraStation Pro Rackmount WSS provides seamless capability with Windows computers and servers. The TeraStation Pro Rackmount WSS incorporates the powerful Intel Atom Dual-Core Processor providing class-leading performance, enabling the ability to focus on concurrent tasks with minimal performance degradation: experience maximum network throughput while a replication job runs in the background or perform fast search indexing while an anti-virus scan is occurring. Additionally, TeraStation Pro Rackmount WSS supports full disk encryption and support for NTFS for very specific file-level security. Native Active Directory support provides integration with large Windows networks.
- BUFFALO TeraStation Pro Rackmount WSS - NAS server - 4 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable
- Total Storage Capacity
- 4 TB
- Installed Devices / Modules Qty
- 4 (installed) / 4 (max)
- 43 cm x 42 cm x 4.4 cm
- 12 kg ()
- Processor
- Intel Atom 1.66 GHz (Dual-Core)
- Storage Controller
- RAID SATA 3Gb/s RAID 0, 1, 5, JBOD
- Hard Drive
- 4 x 1 TB SATA 3Gb/s
- Networking
- Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
- RAM
- 2 GB
- Power
- AC 120/230 V (50/60 Hz)
- Storage Operating System
- Microsoft Windows Storage Server 2008 R2 Workgroup
- System Requirements
- Microsoft Windows 2000, Microsoft Windows 2000 Server, Microsoft Windows XP, Microsoft Windows Server 2003, Apple MacOS X 10.5 or later, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits)
- 3-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Enclosure Type
- Rack-mountable
- 4 TB
- 43 cm
- 42 cm
- 4.4 cm
- 12 kg ()
- Built-in Devices
- Status LCD, print server
Processor / Memory
- Processors Installed
- Number of Cores
- Dual-Core
- RAM
- 2 GB
Storage Controller
- RAID - internal
- Interface Type
- SATA 3Gb/s
- RAID Level
- RAID 0, RAID 1, RAID 5, JBOD
Hard Drive
- HDD - hot-swap
- Capacity
- 4 x 1 TB
- Interface Type
- SATA 3Gb/s
- 256-bit AES
- Data Link Protocol
- TCP/IP, NTP
- Network Services Compatibility
- Microsoft Active Directory (AD), DFS, Microsoft CIFS, Network File System (NFS), Server Message Block (SMB)
- Trunking, load balancing, LDAP support, DFS support, Remote Desktop Protocol (RDP) support, Jumbo Frames support
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab
- Expansion Bays
- 4 (total) / 0 (free) x hot-swap
- 2 x USB 3.0 - Type A , 2 x USB 2.0 - Type A , 2 x Ethernet 1000Base-T - RJ-45
- Built-in 2 cooling fans
- Power Device
- Internal power supply
- Voltage Required
- Software Included
- NovaBACKUP Business Essentials (10 licences)
- OS Required
- Limited warranty - 3 years
- 5 °C
- 35 °C
