Buffalo's LinkStation Pro is a high performance, dependable, shared network storage solution with fast transfer speeds. It is easy to install and lets you store and share music, photos, and videos in your home as well as online. Stream your favorite music and videos directly from the LinkStation Pro to a PC or Mac, PS3, Xbox 360, network attached DLNA media player, iPhone or Buffalo LinkTheater. Access and share your multimedia collection from anywhere at any time using WebAccess. Anyone with a web browser and access credentials to your LinkStation will be able to see your photos, videos and other content. The user-friendly LinkStation Pro makes sharing your digital world, simple!
- High speed Data Transfer of up to 76MB/s
- Built-In Media Server Support - Share movies and play music with the DLNA or UPnP Certified media player
- WebAccess - Access your digital content via a Web browser to a PC or Mac or via the WebAccess-i app to your iPhone, or iPad
- Direct Copy - One touch transfer of media files from any digital camera/camcorder
- Built-in BitTorrent Client
- USB Device server: Connect and share a Multifunction USB 2.0 Printer on your network
Key Specifications
- 10/100/1000 Gigabit Ethernet support
- Built-in DLNA & UPnP CERTIFIED Media Server
- WebAccess - Access your digital content via a Web browser to a PC or Mac or via the WebAccess-i app to your iPhone® or iPad®
- Direct Copy feature allows you to automatically upload images from your digital camera or digital camcorder directly to your LinkStation
- Download media directly to your LinkStation using the built-in BitTorrent client, no need to keep your PC on
- Seamlessly integrates with iTunes® and allows you to access your music files on the LinkStation from your iTunes® software
- Supports Apple Time Machine Backup with multiple clients
- Active Directory Support: Works as a client in an Active Directory domain allowing the LinkStation Pro to utilize the domain users and groups
- Schedule Backups from one LinkStation to another over your LAN network or via USB to an external HDD
- Includes Novastor NovaBACKUP® Professional with 5 licence Pack for PC
- TurboPC / TurboCopy for Windows - increases file transferand copy performance
- Schedule Power Management and PC Interlocking Power Management function
- Eco Friendly Power Saving Mode
- Easy setup and web-based administration
- Protect data by restricting access with group and user level security
- Built-in Print Server to print from anywhere on your network (*USB printers supported only)
- Expand storage by adding a USB hard drive via the USB port
- Built-in FTP server
Web access
Upload and watch photos and files or listen to music from anywhere. -
iPhone support
Use your iPhone to stream and view content. -
Time Machine support
Use the LinkStation Pro with Time Machine. -
Eco-friendly
Unit automatically powers down and saves electric cost. -
iTunes support
Play music from the LinkStation through your iTunes application. -
DLNA Certified
It is Built-in media server to stream content. -
BitTorrent client
Download digital content over the Internet directly to your LinkStation Pro. -
Network servers
FTP and print servers included with the firmware. -
Print server
Share existing printers with others in your home or office. -
USB storage support
Connect USB hard drives to back up or add storage. -
Direct copy
Plug in your USB hard drive or camera to quickly offload pictures.
- BUFFALO LinkStation Pro - NAS server - 2 TB
- NAS server
- Host Connectivity
- Gigabit Ethernet
- Total Storage Capacity
- 2 TB
- 4.5 cm x 15.6 cm x 17.5 cm
- 1.1 kg ()
- Storage Controller
- SATA SATA 1.5Gb/s
- Hard Drive
- 1 x 2 TB SATA 1.5Gb/s
- Networking
- Network adapter - integrated - 10Mb LAN, 100Mb LAN, GigE
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows XP Media Center Edition 2004, Microsoft Windows 7, Microsoft Windows XP Media Center Edition 2005, Apple MacOS X 10.3.9 or later, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2008, Microsoft Windows Vista (32/64 bits)
- 2-year warranty
- NAS server
- Host Connectivity
- Gigabit Ethernet
- 2 TB
- 4.5 cm
- 15.6 cm
- 17.5 cm
- 1.1 kg ()
- Built-in Devices
- Print server
Storage Controller
- SATA - internal
- Interface Type
- SATA 1.5Gb/s
- Supported Devices
- Hard drive
Hard Drive
- HDD
- Capacity
- 1 x 2 TB
- Interface Type
- SATA 1.5Gb/s
- Data Link Protocol
- TCP/IP, NTP, FTP, SMB
- Remote Management Protocol
- HTTP
- Network Services Compatibility
- Microsoft CIFS, FTP, FTPS, Server Message Block (SMB), Apple File Protocol (AFP), HTTP, HTTPS
- Print server, iTunes server, FTP server, Buffalo Web Access, BitTorrent Client, Direct Copy
- IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, DLNA CERTIFIED
- Expansion Bays
- 1 (total) / 0 (free) x internal
- 1 x Ethernet 1000Base-T - RJ-45 , 1 x USB 2.0 - Type A
- Power Device
- External power adapter
- Voltage Required
- 24 Watt
- Software Included
- NovaBACKUP Workstation - Buffalo Edition (5 licences)
- OS Required
- Limited warranty - 2 years
- 5 °C
- 35 °C
- 20 - 80% (non-condensing)
