Help Regular buy list
Your basket is empty
product details header
BT Paragon 650 Corded Phone With Answer Machine
Quicklinx: 52XJWS00 Add to regular buy list
Mfr#: 032116
£45.83 ex VAT
15 in stock
Mobile phone SIM card reader/writer(1)
The BT Paragon has a built-in SIM card reader/writer so there's no need to re-enter all your contacts into your new phone. Just insert your mobile's SIM card into the BT Paragon and copy all the numbers from there. It's also a great way to keep a backup of the numbers stored on your mobile phone.
Answering machine with up to 32 minutes digital recording time
The answering machine has two pre-recorded male and female outgoing messages (answer & record and answer only option) or you can record your own. You can playback messages via the loudspeaker or privately through the handset and you can screen calls. There is a memo feature so you can leave messages for other handset users and you can access your answering machine remotely and listen to your messages when you are away from home.
Text messaging with message storage space(2)
Send and receive text messages from your BT Paragon phone. A flashing light on the base, a message on the display and an audible alert indicate that new text messages have been received.
200 Name and number directory
Your BT Paragon phone can store up to 200 of your most frequently used names and numbers to make dialling quick and easy. If you subscribe to a Caller Display service you can also assign group ringtones when you store directory entries - the assigned ringtone will then play when someone from a particular group calls you.
Caller Display with 50 number calls list(3)
See who is calling you before you answer the phone. The calls list holds details of your last 50 callers, including the phone number and time and date of the call. If a number matches a stored directory entry, the caller's name is displayed as well as the number.
Key features
  • Digital Answering Machine
  • Mobile phone SIM card reader/writer(1)
  • Send and receive text messages(2)
  • 200 Entry directory
  • Caller Display with 50 number calls list(3)
  • Handsfree
Additional features
  • Call Waiting(3)
  • 4 Line backlit, inverse display with contrast control
  • 3 Quickdial numbers
  • 10 Last number redial
  • Secrecy feature
  • Headset port (RJ11)
  • Call and message indicator lights
  • Inductive coupler for hearing aid compatibility
  • BT Select Services button
  • Clock, calendar and alarm functions
  • Ringer volume control Ringtone options - 5 melodies/10 polyphonic
  • Earpiece volume control
  • Switchboard compatible (Tone/Pulse/TBR)
  • Pause/Recall/PBX Access code (Auto Prefix)
Answering machine features
  • Up to 32 minutes digital recording time
  • Pre-recorded male and female outgoing messages: Answer & record and Answer only
  • Facility to record your own outgoing message
  • Answer delay setting
  • Call screening/intercept
  • Message counter
  • Playback via the base or handset
  • Voice prompts
  • Playback volume control
  • Memo facility
  • Memory full alert
  • Answering machine on/off timer function
  • Remote access (security code protected)
What's in the box?
  • BT Paragon 650 corded telephone
  • Telephone line cord
  • Handset with cord
  • Mains power adaptor
  • Desk mounting plinth
  • Quick Start Guide
We do our best to supply our customers with the apparatus they ask for, but we may have to provide apparatus which does not accord exactly with the illustrations and shades of colour shown on the pack. This product is intended for connection to analogue public switched telephone networks and private switchboards in the UK.
1 3G and 5V SIM cards are not compatible with this product. Please check with your network provider first if you are unsure what SIM card you have.
2 You must subscribe to your network provider's Caller Display service for text messaging to work and you must not withhold your number. Your network provider may charge you for these services. Please note some other network provider lines may not be compatible with this text messaging service.
3 You must subscribe to a Caller Display or Call Waiting service for these features to work. Your network provider may charge you for these services.
† Trademark of British Telecommunications plc.
Bundles
* Compared to buying items separately
Bundles
Options (1)
52XJ Durable 5758 Telephone Cleaning Wipes - Box of 100 Out of Stock £2.55
Resources
The following resources are available for the BT Paragon 650 Corded Phone With Answer Machine
