Digital cordless phone with answer machine
Portable – Take your handset away from the base unit for the most freedom while chatting. (Up to 50m indoors and 300m outdoors).
Greater call control - With options to block calls by specific numbers or certain call types.
Easy to set up – Setting up this phone is easy with it’s simple to use menu and 1.6" backlit screen.
Key features
- Blocks up to 50 numbers
- Do not disturb mode
- Up to 20 minutes answer machine recording time
- Save up to 50 contacts
- Up to 10 hours talk and 200 hours standby time
- Greater call control with options to block calls by specific numbers or certain call types*
*To block nuisance calls or use text messaging, you need Caller Display from your network provider. Charges may apply.
- BT 3560 Nuisance Call Blocker - Quad - cordless phone - answering system with caller ID + 3 additional handsets - 3-way call capability
- Product Type
- Cordless phone answering system with caller ID + 3 additional handsets
- Total Number of Wireless Handsets
- 4
- Cordless Phone Standard
- DECT\GAP
- Speakerphone
- Call Services
- Voice Mail, Caller ID, Call Transfer
- Display
- Monochrome - Yes
- Display Features
- Blue backlight
- 1-year warranty
- Product Type
- Additional Handsets Qty
- 3
- 4
Phone Features
- DECT\GAP
- Call Services
- Caller ID Type
- Caller ID
- Max Handsets Supported
- 4
- Max Handset Operating Distance
- 50 m
- Max Handset Operating Distance (Outdoor)
- 300 m
- Dialer Location
- Handset
- Conference Call Capability
- 3-way
- Speakerphone
- Volume Control
- Ring Tones
- 5
- Handset Locator
- Indicators
- New message indicator, low battery indicator, out-of-range indicator, missed call indicator
- Additional Functions
- Call timer, built-in clock, Alarm, Intercom, mute, auto answer, Do Not Disturb (DND), memo recording, up to 50 call blocking numbers, Hands-free calling
Phone Memory
- Phone Directory Capacity
- 50 names & numbers
Answering System
- Recording Capacity
- 20 min
Display
- Monochrome
- Display Location
- Handset
- Diagonal Size
- 1.6"
- Backlit
- Blue backlight
- Included Accessories
- Power adapter, 3 phone charging stands
- Battery
- 2 x battery - AAA type
- Capacity
- 300 mAh
- Technology
- Rechargeable - Nickel Metal Hydride
- Included Qty
- 2
- Talk Time
- Up to 600 min
- Standby Time
- Up to 200h
- Recharge Time
- 8 hour(s)
- Limited warranty - 1 year
