The sleek, compact and stylish Brother QL-570 Professional Label Printer is perfect for creating cost effective labels on demand for envelopes, packages, file folders, CD / DVD, name badges and more... Once you use the Brother QL-570 Label Printer you will discover many more uses for this versatile product. The Brother QL-570 Label Printer is for those wanting to create customized labels quickly and easily so they can look more professional and become more organized.
- Brother QL 570 - label printer - monochrome - direct thermal
- Printer Type
- Label printer - direct thermal - monochrome
- 1.13 kg
- Max Media Size (Standard)
- Roll (6.2 cm)
- Print Speed
- Up to 68 labels/min , Up to 90 mm/sec
- Max Resolution ( B&W )
- 300 x 600 dpi
- Interface
- USB
- Barcodes
- Code 39, UCC/EAN-128, RSS Code, QR code, MaxiCode, EAN/JAN-8 , EAN/JAN-13 , UPC-A, UPC-E, Codabar, Code 128, PDF417, Data Matrix, ITF
- Media Type
- Labels, address labels, file folder labels, CD/DVD labels, shipping labels
- Compatible Tapes
- DK tape
- Styles & Effects
- Vertical, Mirror, rotated text
- System Requirements
- Microsoft Windows 2000 Professional, Microsoft Windows XP, Microsoft Windows Vista, Apple MacOS X 10.3.9 - 10.4.10
- Microsoft Certification
- Works with Windows Vista
- 3 years warranty
- 13.4 cm x 20.8 cm x 14.1 cm
- Printer Type
Printer
- Print Speed
- Up to 68 labels/min - 300x300 dpi , Up to 90 mm/sec
- Built-in Devices
- Cutter
- Connectivity Technology
- Wired
- Interface
- USB
- 300 x 600 dpi
- Styles & Effects
- Auto Cutter
- Barcodes
Media Handling
- Media Type
- Compatible Tapes
- DK tape
- Media Sizes
- Roll (6.2 cm)
- Max Printing Width
- 59 mm
- Max Printing Length
- 914 mm
- Connections
- 1 x USB - 4 PIN USB Type B
- Cables Included
- 1 x USB cable
- Software and devices that carry the Works with Windows Vista logo have been tested for baseline compatibility with PC's running.
- Power Device
- Power supply - internal
- Software Included
- Drivers & Utilities, P-touch Address Book 1.1 for Windows, P-touch Editor 5.0 for Mac OS, P-touch Editor 5.0 for Windows
- OS Required
- Peripheral / Interface Devices
- CD-ROM, USB port
- 3 years warranty
- Service & Support Details
- Limited warranty - 3 years - carry-in
- 13.4 cm
- 20.8 cm
- 14.1 cm
- 1.13 kg
