All-in-one A3 colour printing just got faster and more affordable. Quickly print, copy, scan or fax using the MFC-J5910DW, a model that's compact enough for any office, whether it's at home or at work.
With precision colour printing up to A3, your presentations, projects and photographs can be given more punch than previously possible, whilst our XL cartridges help you considerably reduce running costs. Plus, the latest wireless 'N' technology means you can share the benefits of the small printer with big capability with the rest of the team in your office -or the family at home.
Print, copy, scan, fax with this feature-packed professional series inkjet all-in-one. Make an impression for less with the MFC-J5910dw. Conveniently print 11" x 17" documents while keeping your cost down with super high yield replacement ink cartridges. This powerful business inkjet All-in-One offers built-in auto duplex (two-sided) printing up to 11" x 17" and built-in wireless 802.11b/g/n and Ethernet networking. 1.9" touchscreen color LCD display plus Touch Panel provides easy menu navigation.
Get 12 months free subscription to Trend Micro™ Titanium™ Antivirus+ 2012 with every purchase of a Brother promotional all-in-one printer!
Click here to claim - http://www.brother.eu/g3.cfm/s_page/508380
Duplex printing
Create professional quality two-sided documents up to 11" x 17". -
Built-in wireless and wired interfaces
It is easy-to-setup wireless (802.11 b/g/n) and wired Ethernet networking. -
1.9" touchscreen plus 1.9" touch panel color LCD display
Edit and enhance images and easily navigate through menus. -
High impact up to 11" x 17" (ledger size) printing
Create documents up to 11" x 17" with high impact and easy-to-read details.
- Brother MFC-J5910DW - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Ink-jet (colour)
- Inkjet Technology
- 4-ink
- Max Copying Speed
- Up to 6 ppm (mono) / up to 6 ppm (colour)
- Max Copying Resolution
- Up to 1200 x 1200 dpi (mono) / up to 1200 x 1200 dpi (colour)
- Max Printing Speed
- Up to 12 ppm (mono) / up to 10 ppm (colour)
- Max Printing Resolution
- Up to 6000 x 1200 dpi (mono) / up to 6000 x 1200 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JPEG
- Fax Resolutions
- 203 x 98 dpi, 203 x 196 dpi, 203 x 392 dpi
- Scanning
- 2400 x 2400 dpi
- Display
- 1.9"
- Original Size
- Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 35 sheets
- Media Size
- A3 (297 x 420 mm) (max)
- Media Type
- Transparencies, envelopes, plain paper, photo paper
- Standard Media Capacity
- 250 sheets
- Output Trays Capacity
- 50 sheets
- Automatic Duplexing
- Yes (copying) Yes (printing)
- Connection Availability
- Interface
- USB 2.0, LAN, Wi-Fi(n), USB host
- Office Machine Features
- Print from memory card, save to memory card, save to USB flash drive, scan to e-mail, AOSS
- Power
- AC 230 V (50/60Hz)
- 51.4 cm x 46.1 cm x 26 cm
- 13.6 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 2-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- Ink-jet - colour
- Display Diagonal Size
- 1.9"
- Display Features
- Touch screen
- Interface
- Standard Memory
- 64 MB 64 MB
- Supported Flash Memory
- Memory Stick, SD Memory Card, MultiMediaCard, Memory Stick PRO, USB flash drive, MultiMediaCardplus, SDHC Memory Card
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- 2 on 1, Poster-9, 4 on 1
Printing
- Nozzle Configuration
- 210 nozzles (black), 3 x 210 nozzles (cyan, magenta, yellow)
- Ink Cartridge Configuration
- 4 individual ink tanks
- Ink Palette Supported (Colours)
- Cyan, magenta, yellow, black
- 4-ink
- Minimum Ink Droplet Size
- 1.5 pl
- Ink Type
- Brother Innobella ink
Scanning
- Optical Resolution
- 2400 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- MH, MR, MMR, JPEG
- Fax Resolutions
- Reception Memory Capacity
- Up to 400 pages
- Transmission Memory Capacity
- Up to 400 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- Speed Dialing
- 100 station(s)
- Telephone / Fax Switch
- Broadcast Transmission
- 200 stations
- Remote Fax Retrieval (Polling)
- Yes (black only)
- Fax forwarding, automatic redialing, group dialling, Dual Access, auto reduction, Distinctive Ring Detection (DRD)
Document & Media Handling
- Max Original Size
- Original Type
- Sheets
- 35 sheets
- Max Media Size
- A3
- Min Media Weight
- 64 g/m²
- Max Media Weight
- 220 g/m²
- Supported Media Type
- Supported Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A3 (297 x 420 mm), A6 (105 x 148 mm)
- Borderless Photo Sizes
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm), A3 (297 x 420 mm), A6 (105 x 148 mm)
- 250 sheets
- 50 sheets
- Input tray - 250 sheets - A3 (297 x 420 mm) weight: 64 g/m² - 220 g/m² , ADF - 35 sheets size: 148 x 148 mm - Legal (216 x 356 mm) , Output tray - 50 sheets
- Speed Details
- Printing: up to 35 ppm - B/W , Printing: up to 27 ppm - colour , Copying: up to 23 ppm - B/W , Copying: up to 20 ppm - colour , Printing: up to 12 ipm - B/W (ISO/IEC 24734) , Printing: up to 10 ipm - colour (ISO/IEC 24734) , Copying: up to 6 ipm - B/W (ISO/IEC 24734) , Copying: up to 6 ipm - colour (ISO/IEC 24734)
- 1 x USB 2.0 , 1 x USB host , 1 x LAN
- Network Protocols
- TCP/IP, IPv4
- WEP, WPA-PSK, WPA2-PSK, WPS
- Operating System Support
- MS Windows Server 2003, MS Windows XP Professional x64 Edition, MS Windows 7, Apple Mac OS X 10.6.x, Apple Mac OS X 10.4.11, MS Windows Vista, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, Apple Mac OS X 10.5.x, MS Windows Server 2008, MS Windows Server 2008 R2
- Software Included
- Brother ControlCentre2, Brother MFL-Pro Suite, Reallusion FaceFilter Studio, Presto! PageManager 7 for Mac, ScanSoft PaperPort SE 12.0, Brother ControlCenter4
- Voltage Required
- 21 Watt
- Power Consumption Standby
- 6 Watt
- Power Consumption Sleep
- 3.5 Watt
- Direct Printing Specifications
- PictBridge
- Consumables Included
- 1 x ink cartridge (black) , 1 x ink cartridge (cyan) , 1 x ink cartridge (magenta) , 1 x ink cartridge (yellow)
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 2 years
- 51.4 cm
- 46.1 cm
- 26 cm
- 13.6 kg
- Shipping Width
- 62.5 cm
- Shipping Depth
- 56.5 cm
- Shipping Height
- 37 cm
- Shipping Weight
- 18.7 kg
- Sound Emission
- 50 dBA (operating)
- 10 °C
- 35 °C
- 20 - 80% (non-condensing)
Brother LC1240BK - Print cartridge - 1 x black - 600 pages | In Stock | £18.00 |
Brother LC1240C - Print cartridge - 1 x cyan - 600 pages | In Stock | £11.51 |
Brother LC1240M - Print cartridge - 1 x magenta - 600 pages | In Stock | £11.51 |
Brother LC1240Y - Print cartridge - 1 x yellow - 600 pages | In Stock | £14.00 |
Brother LC1280XLBK - Print cartridge - 1 x black - 2400 pages | In Stock | £25.92 |
Brother LC1280XLC - Print cartridge - 1 x cyan - 1200 pages | In Stock | £15.84 |
Brother LC1280XLM - Print cartridge - 1 x magenta - 1200 pages | In Stock | £15.84 |
Brother LC1280XLY - Print cartridge - 1 x yellow - 1200 pages | In Stock | £15.77 |
Brother LC1280 Inkjet Cartridge Value Pack | In Stock | £71.71 |
Brother LC1240 Black/Cyan/Magenta/Yellow Value Pack | In Stock | £51.23 |
