The MFC-9120CN is a compact and affordable digital color all-in-one solution which combines printing, copying, scanning and faxing into one powerful space-saving device. Delivering brilliant color output, you can produce impact presentations, flyers, brochures and other critical business documents. Enjoy the convenience of stand-alone copying and copy reduction or enlargement from 25-400%. With faxing, you have the flexibility of stand-alone faxing or sending faxes from your PC.
- Brother MFC-9120CN - multifunction printer - colour
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- LED (colour)
- Monthly Duty Cycle (max)
- 25000 impressions
- Recommended Monthly Volume
- 1500 pages
- Max Copying Speed
- Up to 16 ppm (mono) / up to 16 ppm (colour)
- Max Copying Resolution
- Up to 600 x 600 dpi (mono) / up to 600 x 600 dpi (colour)
- Max Printing Speed
- Max Printing Resolution
- Up to 600 x 2400 dpi (mono) / up to 600 x 2400 dpi (colour)
- Max Fax Transmission Speed
- 33.6 Kbps
- Data Compression System
- MH, MR, MMR, JBIG, JPEG
- Scanning
- 1200 x 2400 dpi
- Original Type
- Sheets, books
- Document Feeder Capacity
- 35 sheets
- Media Size
- 76.2 x 116 mm (min) - 220 x 406.4 mm (max)
- Media Type
- Envelopes, plain paper, labels, recycled paper, bond paper
- Standard Media Capacity
- 250 sheets
- Bypass Feeder Capacity
- 1 sheet
- Output Trays Capacity
- 100 sheets
- Connection Availability
- Interface
- USB 2.0, LAN
- Office Machine Features
- Internet faxing, scan to e-mail, scan to folder
- 42.8 cm x 49.1 cm x 40.1 cm
- 22.9 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- ENERGY STAR Qualified, Blue Angel
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- LED - colour
- 25000 impressions
- 1500 pages
- Display
- 2 lines x 16 characters
- Interface
- USB 2.0, LAN
- Standard Memory
- 64 MB 64 MB
- Max Supported Memory
- 576 MB 576 MB
Copying
- Max Copying Speed
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
- Copying Features
- Toner Save, 2 on 1, Poster-16, Poster-4, Poster-9, 4 on 1, 9 on 1, 25 on 1, 16 on 1
Printing
- Printer Drivers / Emulations
- PCL 6, PostScript 3
- First Print Out Time B/W
- 15 sec
- First Print Out Time Colour
- 16 sec
Scanning
- Scan Element
- CIS
- Optical Resolution
- 1200 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Max Battery Backup Time
- 60 hour(s)
- Total Memory Capacity
- Up to 500 pages
- PC Faxing
Fax Machine Features
- Error Correction Mode (ECM)
- One-Touch Dialing
- 8 station(s)
- Speed Dialing
- 200 station(s)
- Telephone / Fax Switch
- Broadcast Transmission
- 258 stations
- Delayed Transmission
- 50 stations
- Remote Fax Retrieval (Polling)
- Fax forwarding, Distinctive Ring Pattern Detection (DRPD), automatic redialing, answering machine interface
Document & Media Handling
- Original Type
- Sheets, books
- 35 sheets
- Min Media Size
- 76.2 x 116 mm
- Max Media Size
- Other
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 163 g/m²
- Supported Media Type
- 250 sheets
- 1 sheet
- 100 sheets
- ADF - 35 sheets , Bypass tray - 1 sheet size: 76.2 x 116 mm - 220 x 406.4 mm weight: 60 g/m² - 163 g/m² , Input tray - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , Output tray - 100 sheets
- Speed Details
- Copying: up to 16 ppm (A4) - B/W , Copying: up to 16 ppm (A4) - colour , Printing: up to 16 ppm (A4) - B/W , Printing: up to 16 ppm (A4) - colour
- 1 x USB 2.0 , 1 x LAN
- Network Protocols
- TCP/IP, NetBEUI, IPP, LPR/LPD, RAW IP (Port 9100)
- Secure Print, SSL, TLS
- Operating System Support
- Linux, MS Windows Server 2003, MS Windows Server 2008 x64 Edition, MS Windows XP Professional x64 Edition, MS Windows Vista, MS Windows 2000 Professional, MS Windows XP Home Edition, MS Windows XP Professional, MS Windows Server 2003 x64 Edition, Apple MacOS X 10.3.9 or later, MS Windows Server 2008
- Software Included
- Drivers & Utilities, Brother BR-Admin Professional, ScanSoft PaperPort SE 11.0, Brother MFL-Pro Suite, Presto! PageManager 7, Brother BR-Admin Light for Linux & Macintosh
- 480 Watt
- Power Consumption Standby
- 75 Watt
- Power Consumption Sleep
- 11 Watt
- Warm-Up Time
- 35 sec
- First Copy Out Time B/W
- 19 sec
- First Copy Out Time Colour
- 24 sec
- Included Accessories
- Phone cable
- Consumables Included
- 1 x toner cartridge (black) - up to 1000 pages , 1 x toner cartridge (cyan) - up to 1000 pages , 1 x toner cartridge (magenta) - up to 1000 pages , 1 x toner cartridge (yellow) - up to 1000 pages , 1 x drum - up to 15000 pages
- ENERGY STAR Certified
- Blue Angel Compliant
- Limited warranty - 1 year - on-site
- 42.8 cm
- 49.1 cm
- 40.1 cm
- 22.9 kg
- Shipping Width
- 73 cm
- Shipping Depth
- 59 cm
- Shipping Height
- 56.5 cm
- Shipping Weight
- 29 kg
- Sound Emission
- 30 dB (idle) / 53 dB (operating)
Brother HL3000 Black 2.2k Toner | In Stock | £50.61 |
Brother TN230C - Toner cartridge - 1 x cyan - 1400 pages | In Stock | £49.00 |
Brother TN230M - Toner cartridge - 1 x magenta - 1400 pages | In Stock | £49.00 |
Brother TN230Y - Toner cartridge - 1 x yellow - 1400 pages | In Stock | £49.00 |
Brother DR230CL DRUM | In Stock | £76.51 |
