Fast, reliable and packed with features - get professional business documents every day with the impressive, network-ready MFC-8880DN.
Offering excellent value for money with low running costs and a vast array of features, the MFC-8880DN is the professional printing solution for your business.
- Brother MFC-8880DN - multifunction printer - B/W
- Multifunction printer
- Copier Type
- Digital
- Fax Type
- Super G3 - plain paper
- Printing Technology
- Laser (monochrome)
- Monthly Duty Cycle (max)
- 30000 impressions
- Max Copying Speed
- Up to 30 ppm
- Max Copying Resolution
- Up to 1200 x 600 dpi
- Max Printing Speed
- Up to 30 ppm
- Max Printing Resolution
- Up to 1200 x 1200 dpi
- Max Fax Transmission Speed
- 33.6 Kbps
- Scanning
- 600 x 2400 dpi
- Original Size
- 148 x 148 mm (min) - Legal (216 x 356 mm) (max)
- Original Type
- Sheets
- Document Feeder Capacity
- 50 sheets
- Media Size
- 69.9 x 116 mm (min) - 216 x 406.4 mm (max)
- Media Type
- Transparencies, envelopes, plain paper, labels, recycled paper
- Standard Media Capacity
- 300 sheets
- Max Media Capacity
- 550 sheets
- Bypass Feeder Capacity
- 50 sheets
- Output Trays Capacity
- 150 sheets
- Automatic Duplexing
- Yes (copying)
- Interface
- Parallel, USB 2.0, LAN, USB host
- Office Machine Features
- Scan to e-mail
- 53.1 cm x 45 cm x 47.5 cm
- 16.7 kg
- Microsoft Certification
- Compatible with Windows 7
- Environmental Standards
- Blue Angel
- 1-year warranty
- Copier Type
- Digital
- Fax Type
- Plain paper
- Laser - monochrome
- 30000 impressions
- Display
- 5 lines
- Interface
- Scan to e-mail
- Standard Memory
- 64 MB 64 MB
- Max Supported Memory
- 576 MB 576 MB
- Supported Flash Memory
- USB flash drive
Copying
- Max Copying Speed
- Up to 30 ppm
- Grayscale Half-Tones
- 256
- Max Document Enlargement
- 400%
- Max Document Reduction
- 25%
- Maximum Copies
- 99
Printing
- Up to 30 ppm
- Printer Drivers / Emulations
- PCL 6, PostScript 3
Scanning
- Optical Resolution
- 600 x 2400 dpi
- Interpolated Resolution
- 19200 x 19200 dpi
- Grayscale Depth
- 8-bit
- Colour Depth
- 24-bit
- Colour Depth (Internal)
- 48-bit
Fax Machine
- Compatibility
- Super G3
- Max Transmission Speed
- 33.6 Kbps
- Total Memory Capacity
- Up to 500 pages
- PC Faxing
Fax Machine Features
- One-Touch Dialing
- 40 station(s)
- Speed Dialing
- 300 station(s)
- Broadcast Transmission
- 390 stations
Document & Media Handling
- Min Original Size
- 148 x 148 mm
- Max Original Size
- Original Type
- Sheets
- 50 sheets
- Min Media Size
- 69.9 x 116 mm
- Max Media Size
- Other
- Min Media Weight
- 60 g/m²
- Max Media Weight
- 161 g/m²
- Supported Media Type
- 300 sheets
- 550 sheets
- 50 sheets
- 150 sheets
- Input tray - 250 sheets size: A6 (105 x 148 mm) - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m² , ADF - 50 sheets size: 148 x 148 mm - Legal (216 x 356 mm) weight: 64 g/m² - 90 g/m² , Bypass tray - 50 sheets size: 216 x 406.4 mm - 69.9 x 116 mm weight: 60 g/m² - 161 g/m² , Output tray - 150 sheets
- Speed Details
- Printing: up to 30 ppm - B/W , Copying: up to 30 ppm - B/W
- 1 x USB 2.0 , 1 x USB host , 1 x parallel , 1 x LAN
- Network Protocols
- TCP/IP, LPR/LPD
- Operating System Support
- MS Windows XP, MS Windows 2000, MS Windows Server 2003, MS Windows Vista, Apple MacOS X 10.3.9 or later, MS Windows Server 2008
- Software Included
- Brother BR-Admin Professional, ScanSoft PaperPort SE 11.0, Brother MFL-Pro Suite
- 660 Watt
- Power Consumption Standby
- 85 Watt
- Power Consumption Sleep
- 17 Watt
- First Copy Out Time B/W
- 10.5 sec
- Consumables Included
- 1 x toner cartridge (black) - up to 3000 pages - Brother TN3230 , 1 x drum - up to 25000 pages - Brother DR3200
- Blue Angel Compliant
- Limited warranty - 1 year - on-site
- 53.1 cm
- 45 cm
- 47.5 cm
- 16.7 kg
- Sound Emission
- 30 dBA (idle) / 55 dBA (operating)
Brother HL5340/5350 High Capacity Toner | In Stock | £101.24 |
Brother TN3230 - Toner cartridge - 1 x black - 3000 pages | In Stock | £65.42 |
