Brother MFC 8380DN - multifunction ( fax / copier / printer / scanner ) ( B/W )
Quicklinx: 6L4TWS00 Mfr#: MFC8380DNZU1
The MFC-8380DN is a fast, network ready, professional all-in-one that offers a fully featured laser printer, copier, fax and color scanner. The integrated technology and fully automatic duplex function mean that documents will look professional at all times - the ideal solution for any office.
Brother MFC-8380DN - multifunction printer - B/W
Multifunction printer
Copier Type
Digital
Fax Type
G3 - plain paper
Printing Technology
Laser (monochrome)
Max Copying Speed
Up to 30 ppm
Max Copying Resolution
Up to 1200 x 600 dpi
Max Printing Speed
Up to 30 ppm
Max Printing Resolution
Up to 1200 x 1200 dpi
Max Fax Transmission Speed
33.6 Kbps
Data Compression System
MH, MR, MMR, JBIG
Scanning
600 x 2400 dpi
Original Size
148 x 148 mm (min) - 216 x 356 mm (max)
Original Type
Sheets
Document Feeder Capacity
20 sheets
Media Size
69.9 x 116 mm (min) - 216 x 406.4 mm (max)
Media Type
Transparencies, envelopes, plain paper, recycled paper
Standard Media Capacity
300 sheets
Bypass Feeder Capacity
50 sheets
Output Trays Capacity
150 sheets
Automatic Duplexing
Yes (copying)
Connection Availability
USB, LAN, USB host
Office Machine Features
Print from USB flash drive, save to USB flash drive
53.1 cm x 45.1 cm x 47.5 cm
18.6 kg
Microsoft Certification
Compatible with Windows 7
Environmental Standards
ENERGY STAR Qualified
1-year warranty
Copier Type
Digital
Fax Type
Plain paper
Printing Technology
Laser - monochrome
Display
2 lines x 16 characters
USB, LAN, USB host
Standard Memory
64 MB 64 MB
Max Supported Memory
576 MB 576 MB
Copying
Max Copying Speed
Up to 30 ppm
Grayscale Half-Tones
256
Max Document Enlargement
400%
Max Document Reduction
25%
Maximum Copies
99
Automatic Duplexing
Copying Features
2 on 1, 4 on 1
Printing
Max Printing Speed
Up to 30 ppm
Printer Drivers / Emulations
PCL 6, IBM Proprinter, BR-Script 3
Image Enhancement Technology
Brother HQ1200
Scanning
Optical Resolution
600 x 2400 dpi
Interpolated Resolution
9600 x 9600 dpi
Grayscale Depth
8-bit
Colour Depth
24-bit
Colour Depth (Internal)
48-bit
Fax Machine
Compatibility
G3
Max Transmission Speed
33.6 Kbps
MH, MR, MMR, JBIG
Total Memory Capacity
Up to 500 pages
PC Faxing
Fax Machine Features
Error Correction Mode (ECM)
Speed Dialing
300 station(s)
Document & Media Handling
Min Original Size
148 x 148 mm
Max Original Size
216 x 356 mm
Original Type
Sheets
20 sheets
Min Media Size
69.9 x 116 mm
Max Media Size
Other
Min Media Weight
60 g/m²
Max Media Weight
163 g/m²
Supported Media Type
300 sheets
50 sheets
150 sheets
Input tray - 250 sheets , ADF - 50 sheets , Output tray - 150 sheets , Bypass tray - 50 sheets
Speed Details
Copying: up to 30 ppm - B/W , Printing: up to 30 ppm - B/W , Printing: up to 9 ppm - B/W duplex
1 x USB , 1 x USB host , 1 x LAN
Operating System Support
MS Windows XP, Linux, MS Windows Server 2003, MS Windows Vista, MS Windows 2000 Professional, Apple MacOS X 10.3.9 or later, MS Windows Server 2008
Software Included
Drivers & Utilities
680 Watt
Power Consumption Standby
85 Watt
Power Consumption Sleep
19 Watt
Warm-Up Time
18 sec
First Copy Out Time B/W
10.5 sec
Consumables Included
1 x toner cartridge (black) - up to 2000 pages
ENERGY STAR Certified
Limited warranty - 1 year - on-site
53.1 cm
45.1 cm
47.5 cm
18.6 kg
Shipping Width
62.8 cm
Shipping Depth
56.7 cm
Shipping Height
57.5 cm
Shipping Weight
21.1 kg
Sound Emission
4.6 dB (idle) / 56 dB (operating)
6L4T Brother HL5340/5350 High Capacity Toner In Stock £101.24
6L4T Brother TN3230 - Toner cartridge - 1 x black - 3000 pages In Stock £65.24
