Brother HL3150CDW Colour Laser Printer
Quicklinx: 8P2KWS00 Mfr#: HL3150CDWZU1
The sleek HL-3150CDW is packed with great features designed to meet the demands of your busy office.
Fast, efficient and reliable, this compact printer offers low energy consumption, plus double-sided printing and optional high-yield colour toner cartridges to keep costs down.
Get connected quickly, and easily save and share resources across your network thanks to built-in wireless functionality. You can even print direct from your mobile device with Apple AirPrint or Google Cloud Print .
And, most importantly of all, the colour HL-3150CDW makes your ideas look brighter, so your business always stands out.
Brother HL-3150CDW - printer - colour - LED
Printer Type
Workgroup printer - LED - colour
17.8 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 116 mm
Max Media Size (Custom)
216 mm x 356 mm
Print Speed
Up to 18 ppm - B/W - A4 (210 x 297 mm) , Up to 18 ppm - colour - A4 (210 x 297 mm) , Up to 19 ppm - B/W - ANSI A (Letter) (216 x 279 mm) , Up to 19 ppm - colour - ANSI A (Letter) (216 x 279 mm) , Up to 7 spm - B/W duplex - ANSI A (Letter) (216 x 279 mm) , Up to 7 spm - colour duplex - ANSI A (Letter) (216 x 279 mm) , Up to 7 spm - B/W duplex - A4 (210 x 297 mm) , Up to 7 spm - colour duplex - A4 (210 x 297 mm)
Max Resolution (B&W)
600 x 2400 dpi
Max Resolution (Colour)
600 x 2400 dpi
Automatic Duplexing
USB 2.0, LAN, Wi-Fi(n)
AirPrint Enabled
RAM Installed (Max)
64 MB
Language Simulation
Windows GDI driver
Media Type
Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, thin paper
Total Media Capacity
250 sheets
Media Handling
250-sheet input tray, 1-sheet multipurpose tray
Print server
Printer Features
AirStation OneTouch Secure System (AOSS)
Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Server 2008, Apple MacOS X 10.7.x, Windows 8, Apple MacOS X 10.6.8, Microsoft Windows Server 2012, Apple MacOS X 10.8.x
Microsoft Certification
Compatible with Windows 7
41 cm x 46.5 cm x 24 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wireless
AirPrint Enabled
600 x 2400 dpi
600 x 2400 dpi
Automatic Duplexing
First Print Out Time B/W
16 sec
First Print Out Time Colour
16 sec
Language Simulation
Windows GDI driver
Printer Features
Media Handling
RAM
RAM Installed (Max)
64 MB
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 116 mm
216 mm x 356 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm)
Media Weight
60 g/m² - 163 g/m²
250 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x manual - 1 sheet - Legal (216 x 356 mm) weight: 60 g/m² - 163 g/m²
Output Trays Capacity
100 sheets
Print server
Security Protocols & Features
Kerberos, SSL, WEP, WPA-PSK, TLS, 802.1x, WPA2-PSK, WPS, ARP, Wi-Fi Direct
1 x LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B
Consumables Included
1 x toner cartridge (black) - up to 1000 pages ISO/IEC 19798 , 1 x toner cartridge (cyan) - up to 1000 pages ISO/IEC 19798 , 1 x toner cartridge (magenta) - up to 1000 pages ISO/IEC 19798 , 1 x toner cartridge (yellow) - up to 1000 pages ISO/IEC 19798
Power supply - internal
Frequency Required
50/60 Hz
335 Watt
Power Consumption Stand by / Sleep
60 Watt
Environmental Standards
Blue Angel
ENERGY STAR
10 °C
32.5 °C
20 - 80% (non-condensing)
Sound Emission (Idle)
33 dBA
Sound Emission (Operating)
53 dBA
41 cm
46.5 cm
24 cm
17.8 kg
8P2K Brother TN241BK Toner Cartridge Black In Stock £48.30
8P2K Brother TN241C Toner Cartridge Cyan In Stock £47.90
8P2K Brother TN241M Toner Cartridge Magenta In Stock £47.90
8P2K Brother TN241Y Toner Cartridge Yellow In Stock £50.93
8P2K Brother TN245C Toner Cartridge Cyan In Stock £67.91
8P2K Brother TN245M Toner Cartridge Magenta In Stock £67.91
8P2K Brother TN245Y Toner Cartridge Yellow In Stock £67.91
8P2K Brother Drum Unit yield 15k In Stock £72.88
8P2K Brother Belt Unit HL3140/MFC9140 50K In Stock £68.80
8P2K Brother Waste Toner HL3140CW/MFC9140 50K In Stock £13.90
