It takes a printer that's strong on both capacity and flexibility to truly support a workgroup and the HL-6180DW hits both marks head on.
With a print speed of up to 40ppm and a standard paper capacity of 550 sheets, you also have the option of a high-yield toner cartridge that's capable of delivering up to 12,000 pages. Resolution operates at 1,200dpi, so print quality is never an issue. You'll save on paper costs too, with automatic duplex and booklet printing.
And, however your office works, the HL-6180DW's Ethernet and Wi-Fi connectivity offers all the flexibility options you need.
High-speed, professional output
With a print speed of up to 42 pages per minute, this printer is ideal for busy offices. Plus, it offers up to 1200 x 1200 dpi resolution for crisp, clear text and excellent graphics. -
Flexible connectivity
Built-in wireless 802.11 b/g/n and Gigabit Ethernet network interfaces allow you to share the HL-6180DW with multiple users on your network. Eliminate extra cables and conveniently place your printer with wireless networking or connect locally to its Hi-Speed USB 2.0 interface. -
Low cost printing
Spend less time replacing supplies and produce low cost output via 12,000-page super high-yield replacement toner cartridge. -
Automatic two-sided printing
Use the duplex feature to produce professional brochures, documents and booklets. This feature can help save money and cut your paper usage in half. -
Advanced security features
Offers a wide-range of security features including: secure print, secure function lock, enterprise security (802.1x) and more. -
Easy to set up and use
Users with wireless access points that support Wi-Fi Protected Setup or AOSS can automatically configure their wireless settings by simply pressing a button on their router.
- Brother HL-6180DW - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 11.5 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 69.8 mm x 116 mm
- Max Media Size (Custom)
- 216 mm x 406.4 mm
- Print Speed
- Up to 40 ppm - B/W
- Max Resolution (B&W)
- 1200 dpi
- Automatic Duplexing
- Interface
- USB, Gigabit LAN, Wi-Fi(n)
- AirPrint Enabled
- Processor
- 400 MHz
- RAM Installed (Max)
- 128 MB (384 MB) - DDR2 SDRAM - SO-DIMM 144-pin
- Language Simulation
- PCL 6, BR-Script3, IBM ProPrinter XL, EPSON FX-850
- Barcodes
- Code 39, ISBN, EAN/JAN-8, EAN/JAN-13, UPC-A, UPC-E, Codabar, Interleaved 2 of 5, Postnet, FIM, Code 128B, Code 128C, Code 128A
- Media Type
- Envelopes, transparencies, labels, plain paper, bond paper, recycled paper, thick paper
- Total Media Capacity
- 550 sheets
- Media Handling
- 500-sheet input tray, 50-sheet multipurpose tray
- Networking
- Print server - Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- System Requirements
- Linux, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows Server 2008 R2, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008, Microsoft Windows Server 2008 x64 Edition, Apple MacOS X 10.5.8, Apple MacOS X 10.6.x, Apple MacOS X 10.7.x
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 37.1 cm x 38.4 cm x 28.8 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wireless
- Interface
- AirPrint Enabled
- 1200 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 8.5 sec
- Fonts Included
- 66 x scalable PCL , 66 x PostScript , 12 x bitmapped PCL
- Barcodes
- Media Handling
- Processor
- 400 MHz
RAM
- 128 MB / 384 MB (max)
- Technology / Form Factor
- Slots Qty
- 1
- Empty Slots
- 1
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 69.8 mm x 116 mm
- 216 mm x 406.4 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), A6 (105 x 148 mm), B6 (125 x 176 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 550 sheets
- Media Feeders
- 1 x automatic - 50 sheets - 215.9 x 406.4 mm weight: 60 g/m² - 163 g/m² , 1 x automatic - 500 sheets - A4 (210 x 297 mm) weight: 60 g/m² - 105 g/m²
- Max Media Capacity
- 1050 sheets
- Output Trays Capacity
- 150 sheets
- Networking
- Print server
- Data Link Protocol
- TCP/IP, NetBEUI/NetBIOS, ICMP/IP, LPR/LPD, ARP, SMTP, FTP, APOP, BOOTP, DHCP, DNS, RARP
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, TFTP
- Kerberos, Secure Print, SSL, LEAP, WEP, WPA-PSK, TLS, WPA2-PSK, TKIP, AES, WPS
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x Gigabit LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 8000 pages ISO/IEC 19752 - Brother TN3380 , 1 x drum - up to 30000 pages - Brother DR3300
- Power Device
- Power supply - internal
- 701 Watt
- Power Consumption Stand by / Sleep
- 4.9 Watt
- OS Required
- Limited warranty - 1 year
- Sound Emission (Idle)
- 34 dBA
- Sound Emission (Operating)
- 59 dBA
- 37.1 cm
- 38.4 cm
- 28.8 cm
- 11.5 kg
- Width (Shipping)
- 49.9 cm
- Depth (Shipping)
- 47.8 cm
- Height (Shipping)
- 41.1 cm
- Weight (Shipping)
- 13.6 kg
Brother TN3330 Toner Cartridge - Black | In Stock | £57.26 |
Brother TN3380 Black Toner Cartridge | In Stock | £90.22 |
Brother TN3390 Toner Cartridge - Black | In Stock | £101.69 |
