Brother HL-4140CN Colour Laser Printer
Quicklinx: 7C37WS00 Mfr#: HL4140CNZU1
Choose the HL-4140CN for professional results you can be proud of.
This fast, reliable printer is both environmentally and budget friendly thanks to its super low power consumption and optional high-yield toner cartridges. You can also set monthly print volume allowances and restrict user access to keep a closer eye on your running costs.
A colour and mono printing rate of 22ppm saves you valuable time around the office, while the expandable 50-sheet multipurpose tray provides added capacity and flexibility.
And the HL-4140CN also offers security encryption to protect any data you send to print.
Brother HL-4140CN - printer - colour - laser
Printer Type
Workgroup printer - laser - colour
21 kg
Media Size Class
A4/Legal
Max Media Size
Legal (216 x 356 mm), A4 (210 x 297 mm)
Min Media Size (Custom)
76.2 mm x 116 mm
Max Media Size (Custom)
220 mm x 406.4 mm
Print Speed
Up to 22 ppm - B/W , Up to 22 ppm - colour
Max Resolution (B&W)
2400 x 600 dpi
USB, LAN, USB host
400 MHz
RAM Installed (Max)
128 MB (384 MB) - DDR2 SDRAM - SO-DIMM 144-pin
Language Simulation
PostScript 3, PCL 6, PDF 1.7
Media Type
Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, glossy paper
Total Media Capacity
300 sheets
Media Handling
250-sheet input tray, 50-sheet multipurpose tray
Print server - Ethernet, Fast Ethernet - integrated
Linux, Microsoft Windows 2000 Professional, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Server 2003 x64 Edition, Apple MacOS X 10.5.x, Apple MacOS X 10.4.11, Microsoft Windows Vista (32/64 bits), Apple MacOS X 10.6.x, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits)
Microsoft Certification
Compatible with Windows 7
1-year warranty
41 cm x 48.6 cm x 31.3 cm
Printer Type
Printer
Print Speed
Built-in Devices
Status LCD
Wired
USB, LAN, USB host
2400 x 600 dpi
PostScript Support
Standard
First Print Out Time B/W
16 sec
Language Simulation
Fonts Included
66 x scalable PCL , 12 x bitmapped , 13 x barcode , 66 x PostScript
Media Handling
400 MHz
RAM
RAM Installed (Max)
128 MB / 384 MB (max)
Technology / Form Factor
Media Handling
Media Type
Media Size Class
A4/Legal
Max Media Size
76.2 mm x 116 mm
220 mm x 406.4 mm
Media Sizes
ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), B6 (125 x 176 mm)
Media Weight
60 g/m² - 163 g/m²
300 sheets
Media Feeders
1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x automatic - 50 sheets - 220 x 406.4 mm weight: 60 g/m² - 163 g/m²
Max Media Capacity
800 sheets
Output Trays Capacity
150 sheets
Print server - integrated
Network / Transport Protocol
LPR/LPD, ARP, SMTP, FTP, APOP, BOOTP, DHCP, DNS, RARP
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, FTP, TFTP
Security Protocols & Features
Kerberos, Secure Print, SSL, LEAP, 802.1x
Expansion Slots
Memory - SO-DIMM 144-pin
1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x direct print port - 4 pin USB Type A
Consumables Included
1 x toner cartridge (black) - up to 2500 pages , 1 x toner cartridge (cyan) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages
Power supply - internal
560 Watt
Power Consumption Stand by / Sleep
65 Watt
Software Included
Drivers & Utilities
Environmental Standards
Blue Angel
ENERGY STAR
Limited warranty - 1 year , Technical support - lifetime
Sound Emission (Idle)
33 dB
Sound Emission (Operating)
57 dB
41 cm
48.6 cm
31.3 cm
21 kg
Width (Shipping)
65 cm
Depth (Shipping)
57.4 cm
Height (Shipping)
52.1 cm
7C37 Brother TN320BK Black Toner Cartridge 2.5K In Stock £46.57
7C37 Brother TN320C 1.5k Cyan Toner In Stock £63.69
7C37 Brother TN320M 1.5k Magenta Toner In Stock £63.69
7C37 Brother TN320Y 1.5k Yellow Toner In Stock £63.69
7C37 Brother TN325C - Toner cartridge - 1 x cyan - 3500 pages In Stock £112.49
7C37 Brother TN325m - Toner cartridge - 1 x magenta - 3500 pages In Stock £112.49
7C37 Brother TN325Y - Toner cartridge - 1 x yellow - 3500 pages In Stock £112.49
7C37 Brother DR-320CL DRUM UNIT C/M/Y/K In Stock £130.21
