Choose the HL-4140CN for professional results you can be proud of.
This fast, reliable printer is both environmentally and budget friendly thanks to its super low power consumption and optional high-yield toner cartridges. You can also set monthly print volume allowances and restrict user access to keep a closer eye on your running costs.
A colour and mono printing rate of 22ppm saves you valuable time around the office, while the expandable 50-sheet multipurpose tray provides added capacity and flexibility.
And the HL-4140CN also offers security encryption to protect any data you send to print.
- Brother HL-4140CN - printer - colour - laser
- Printer Type
- Workgroup printer - laser - colour
- 21 kg
- Media Size Class
- A4/Legal
- Max Media Size
- Legal (216 x 356 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 116 mm
- Max Media Size (Custom)
- 220 mm x 406.4 mm
- Print Speed
- Up to 22 ppm - B/W , Up to 22 ppm - colour
- Max Resolution (B&W)
- 2400 x 600 dpi
- Interface
- USB, LAN, USB host
- Processor
- 400 MHz
- RAM Installed (Max)
- 128 MB (384 MB) - DDR2 SDRAM - SO-DIMM 144-pin
- Language Simulation
- PostScript 3, PCL 6, PDF 1.7
- Media Type
- Envelopes, labels, plain paper, bond paper, recycled paper, thick paper, glossy paper
- Total Media Capacity
- 300 sheets
- Media Handling
- 250-sheet input tray, 50-sheet multipurpose tray
- Networking
- Print server - Ethernet, Fast Ethernet - integrated
- System Requirements
- Linux, Microsoft Windows 2000 Professional, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Server 2003 x64 Edition, Apple MacOS X 10.5.x, Apple MacOS X 10.4.11, Microsoft Windows Vista (32/64 bits), Apple MacOS X 10.6.x, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits)
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 41 cm x 48.6 cm x 31.3 cm
- Printer Type
Printer
- Print Speed
- Built-in Devices
- Status LCD
- Connectivity Technology
- Wired
- Interface
- 2400 x 600 dpi
- PostScript Support
- Standard
- First Print Out Time B/W
- 16 sec
- Fonts Included
- 66 x scalable PCL , 12 x bitmapped , 13 x barcode , 66 x PostScript
- Media Handling
- Processor
- 400 MHz
RAM
- 128 MB / 384 MB (max)
- Technology / Form Factor
Media Handling
- Media Type
- Media Size Class
- A4/Legal
- Max Media Size
- 76.2 mm x 116 mm
- 220 mm x 406.4 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Legal (216 x 356 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), Folio (216 x 330 mm), JIS B5 (182 x 257 mm), B6 (125 x 176 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 300 sheets
- Media Feeders
- 1 x automatic - 250 sheets - Legal (216 x 356 mm) weight: 60 g/m² - 105 g/m² , 1 x automatic - 50 sheets - 220 x 406.4 mm weight: 60 g/m² - 163 g/m²
- Max Media Capacity
- 800 sheets
- Output Trays Capacity
- 150 sheets
- Networking
- Print server - integrated
- Data Link Protocol
- LPR/LPD, ARP, SMTP, FTP, APOP, BOOTP, DHCP, DNS, RARP
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 3, IPP, SNMP 2c, HTTP, HTTPS, FTP, TFTP
- Kerberos, Secure Print, SSL, LEAP, 802.1x
- Expansion Slots
- Memory - SO-DIMM 144-pin
- Connections
- 1 x Gigabit LAN - RJ-45 , 1 x USB 2.0 - 4 pin USB Type B , 1 x direct print port - 4 pin USB Type A
- Consumables Included
- 1 x toner cartridge (black) - up to 2500 pages , 1 x toner cartridge (cyan) - up to 1500 pages , 1 x toner cartridge (magenta) - up to 1500 pages , 1 x toner cartridge (yellow) - up to 1500 pages
- Power Device
- Power supply - internal
- 560 Watt
- Power Consumption Stand by / Sleep
- 65 Watt
- Software Included
- Drivers & Utilities
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Limited warranty - 1 year , Technical support - lifetime
- Sound Emission (Idle)
- 33 dB
- Sound Emission (Operating)
- 57 dB
- 41 cm
- 48.6 cm
- 31.3 cm
- 21 kg
- Width (Shipping)
- 65 cm
- Depth (Shipping)
- 57.4 cm
- Height (Shipping)
- 52.1 cm
Brother TN320BK Black Toner Cartridge 2.5K | In Stock | £46.69 |
Brother TN320C 1.5k Cyan Toner | In Stock | £63.69 |
Brother TN320M 1.5k Magenta Toner | In Stock | £63.69 |
Brother TN320Y 1.5k Yellow Toner | In Stock | £63.69 |
Brother TN325C - Toner cartridge - 1 x cyan - 3500 pages | In Stock | £112.49 |
Brother TN325m - Toner cartridge - 1 x magenta - 3500 pages | In Stock | £112.49 |
Brother TN325Y - Toner cartridge - 1 x yellow - 3500 pages | In Stock | £112.49 |
Brother DR-320CL DRUM UNIT C/M/Y/K | In Stock | £130.21 |
