High Speed Wireless Mono Laser Duplex Printer
The HL-2270DW is a monochrome laser printer that offers an automatic duplex capability for printing two-sided documents with ease, fast printing at up to 27 pages per minute, and built-in wired and wireless networking for sharing with others. It features a stylish, space-saving design that fits virtually anywhere and complements any environment. In addition, it offers convenient paper handling via an adjustable tray. Affordable to own and operate, the HL-2270DW uses a high-yield replacement toner cartridge to help reduce your operating costs.
Compact footprint makes this ideal for a small office where space is at a premium
Save time with fast 26ppm print speed
Save paper with double-sided printing as standard
Easy wireless set-up, plus extra peace of mind with the latest wireless security
Separate drum and toner to help keep costs down - only replace the one that's run out
1,200 page toner in the box
Less refilling with a 250 sheet paper capacity
Network Ready
Added peace of mind with free 12-month warranty and lifetime technical support
Green and clean technology that meets Energy Star and Blue Angel environmental standards
Flexible networking
Built-in wireless 802.11b/g and Ethernet network interfaces allow you to share this printer with multiple users on your network. Eliminate extra cables and conveniently place your printer with wireless networking. -
Easily print two-sided documents
Produce professional-looking two-sided documents, brochures and booklets using the automatic duplex printing feature. This feature can help reduce your paper use and save money. -
Convenient paper handling
The HL-2270DW can meet all of your printing needs via an adjustable paper tray that easily handles letter or legal size paper and a manual feed slot for printing envelopes and letterhead. -
Easy to set up and use
Users with wireless access points that support Wi-Fi Protected Setup or AOSS can automatically configure their wireless settings by simply pressing a button on their router. -
High-quality output
With a print resolution up to 2400 x 600-dpi, the HL-2270DW produces professional-looking output with crisp text and excellent graphics. -
Toner save mode
Use less toner and save money by using toner save mode for your less critical business documents.
- Brother HL-2270DW - printer - B/W - laser
- Printer Type
- Workgroup printer - laser - B/W
- 7 kg
- Media Size Class
- A4
- Max Media Size
- ANSI A (Letter) (216 x 279 mm), A4 (210 x 297 mm)
- Min Media Size (Custom)
- 76.2 mm x 116 mm
- Max Media Size (Custom)
- 216 mm x 406.4 mm
- Print Speed
- Up to 26 ppm - B/W
- Max Resolution (B&W)
- 2400 x 600 dpi
- Automatic Duplexing
- Interface
- USB, LAN, Wi-Fi
- Processor
- ARM9 200 MHz
- RAM Installed (Max)
- 32 MB
- Language Simulation
- PCL 6
- Media Type
- Envelopes, labels, plain paper, bond paper, recycled paper, thick paper
- Total Media Capacity
- 250 sheets
- Media Handling
- 250-sheet input tray, 1-sheet manual tray
- Networking
- Print server - Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g
- Printer Features
- AirStation OneTouch Secure System (AOSS)
- System Requirements
- Linux, Microsoft Windows 2000 Professional, Microsoft Windows XP Home Edition, Microsoft Windows XP Professional, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows XP Professional x64 Edition, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Microsoft Windows Server 2003 x64 Edition, Microsoft Windows Vista (64-bit versions), Microsoft Windows Server 2008, Apple MacOS X 10.4.11 or later, Microsoft Windows Server 2008 x64 Edition
- Microsoft Certification
- Compatible with Windows 7
- 1-year warranty
- 36.8 cm x 36 cm x 18.3 cm
- Printer Type
- Workgroup printer - laser - monochrome
Printer
- Print Speed
- Connectivity Technology
- Wireless
- Interface
- USB, LAN, Wi-Fi
- 2400 x 600 dpi
- PCL 6
- Fonts Included
- 66 x scalable , 12 x bitmapped , 13 x barcode
- Printer Features
- Media Handling
- Processor
- ARM9 200 MHz
RAM
- 32 MB
Media Handling
- Media Type
- Media Size Class
- A4
- Max Media Size
- 76.2 mm x 116 mm
- 216 mm x 406.4 mm
- Media Sizes
- ANSI A (Letter) (216 x 279 mm), Executive (184 x 267 mm), A4 (210 x 297 mm), A5 (148 x 210 mm), B5 (176 x 250 mm), A6 (105 x 148 mm), JIS B5 (182 x 257 mm), B6 (125 x 176 mm)
- Media Weight
- 60 g/m² - 163 g/m²
- 250 sheets
- Media Feeders
- 1 x automatic - 250 sheets weight: 60 g/m² - 105 g/m² , 1 x manual - 1 sheet weight: 60 g/m² - 163 g/m²
- Output Trays Capacity
- 100 sheets
- Networking
- Print server
- Data Link Protocol
- LPR/LPD, ARP, SMTP, APOP, BOOTP, DHCP, DNS, RARP
- Remote Management Protocol
- SNMP 1, IPP, SNMP 2c, HTTP, TFTP
- WEP, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11g
- Connections
- 1 x USB 2.0 - 4 pin USB Type B , 1 x LAN - RJ-45
- Consumables Included
- 1 x toner cartridge (black) - up to 1200 pages - Brother TN-2110 , 1 x drum - Brother DR2200
- Power Device
- Power supply - internal
- 495 Watt
- Power Consumption Stand by / Sleep
- 65 Watt
- OS Required
Environmental Standards
- Blue Angel
- ENERGY STAR
- Limited warranty - 1 year
- Sound Emission (Idle)
- 31 dB
- Sound Emission (Operating)
- 53 dB
- 36.8 cm
- 36 cm
- 18.3 cm
- 7 kg
- Width (Shipping)
- 47.5 cm
- Depth (Shipping)
- 45.4 cm
- Height (Shipping)
- 33.1 cm
- Weight (Shipping)
- 8.3 kg
Brother TN2220 - Toner cartridge - 1 - 2600 pages | In Stock | £47.12 |
Brother BRO DR2200 DRUM HL2240/2240D/ | In Stock | £53.50 |
Brother TN2210 - Toner cartridge - 1 - 1200 pages | In Stock | £30.48 |
