Brother High Capacity Magenta Toner
Quicklinx: 8J3FWS00 Mfr#: TN328M
Type: Toner Cartridge
Technology: Laser
Hurry, only 2 left in stock!
£136.68 ex VAT
£164.01 inc VAT
Original Brother toner is formulated to meet high quality resolution, gray scale and block color, in line with Brother's high design specification.
But don't be tempted to cut corners by using cheap consumables, as this can mean poor results. The manufacturer's original consumables will always be the best choice, as they have been designed to deliver the best performance.
Toner particle size, shape and color pigmentation all have a direct impact on the sharpness of the printed image. Brother's toner is formulated to exacting standards to ensure you receive high quality print resolution and reliability.
Only by using Original Brother consumables can you enjoy the ongoing improvements and technical changes that occur regularly throughout the life of your product.
Brother TN328M - magenta - original - toner cartridge
Toner cartridge
Printing Technology
Laser
Printing Colour
Magenta
Yield
Up to 6000 pages ISO/IEC 19798
Compatible with
Brother DCP-9270CDN, HL-4570CDW, HL-4570CDWT, MFC-9970CDW
Dimensions (WxDxH) / Weight
30.3 cm x 9.34 cm x 7.25 cm / 552 g
Shipping Width
34 cm
Shipping Depth
12 cm
Shipping Height
18.3 cm
Shipping Weight
910 g
Consumable
Consumable Type
Toner cartridge
Printing Technology
Laser
Magenta
Included Qty
1-pack
Yield
Compatible with
Technology: Laser
Brand: Brother
