With 24 page per minute (48 images per minute) scan speed through the 50 sheet Automatic Document Feeder (ADF), the ADS-2100e is perfect for small to medium office environments. Scan and archive documents quickly and easily with scan-to Searchable PDF and a range of bundled software.
The multipage detection feature identifies paper feed errors; helping to preserve original documents and maintain clear scanned images, whilst the easy to use touch button panel enables scanning direct to a USB storage device or computer.
Reliable productivity
Delivering fast, high quality 2-sided scanning, the ADS-2100e offers improved performance and image processing with Kofax compatibility and enhanced scan features. -
Color dropout
Remove unwanted colors to improve readability and document clarity. -
Mixed media input
Capture a range of mono and color documents including ID badges and business cards. -
One touch scanning
Convert hard copies to digital files quickly and easily with the touch of a button. -
Efficient
Streamline your workflow by scanning documents directly to a USB flash memory drive for PC free scanning. -
Blank page detection
When scanning a batch of documents the ADS-2100e will detect and remove any blank pages to save time and space whilst archiving. -
Ultrasonic multi-feed detection
Limit the risk of document damage and misfeeds, reducing scanned data loss and maintaining the original paperwork.
- Brother ADS-2100e - document scanner - desktop - USB 2.0, USB 2.0 (Host)
- Document scanner - desktop
- Interface Type
- Additional Functions
- Email, scan to file
- Max Supported Document Size
- 215.9 x 863 mm
- Input Type
- Grayscale / Color Depth
- 8-bit (256 colours) / 30-bit colour
- Grayscale / Color Depth (External)
- 24-bit (16.7 million colours)
- Optical Resolution
- 600 dpi x 600 dpi
- Interpolated Resolution
- 1200 dpi x 1200 dpi
- Max Document Scan Speed
- 24 ppm (mono) / 24 ppm (colour)
- Max Document Size
- 215.9 mm x 863 mm
- Automatic Duplexing
- Supported Document Type
- Plain paper, business card, plastic card
- Document Feeder Type
- Automatic
- Document Storage Capacity
- 50 sheets
- Power
- AC 230V (50/60 Hz)
- System Requirements
- Linux, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Apple MacOS X 10.6 or later, Windows 8, Apple MacOS X 10.8.x, Apple MacOS X 10.7.5, Apple MacOS X 10.9.x
- 29.9 cm x 22 cm x 17.9 cm
- 3.3 kg
- Environmental Standards
- ENERGY STAR Qualified
- Interface Type
- 215.9 x 863 mm
Scanner
- Input Type
- Grayscale Depth
- Colour Depth
- 30-bit colour
- Colour Depth (External)
- 600 dpi x 600 dpi
- Scan Mode
- Single-pass
- Max Document Scan Speed B/W
- 24 ppm
- Max Document Scan Speed Colour
- 24 ppm
- Scanner Speed Details
- 24 ppm - black & white - A4 , 24 ppm - colour - A4 , 48 ipm - duplex - black & white - A4 , 48 ipm - duplex - colour - A4
- Scanner Features
- Scan to portable USB drive, Ultrasonic multifeed sensor
- TWAIN, ISIS, WIA
Media Handling
- Max Document Size
- 215.9 mm x 863 mm
- Supported Document Size Details
- ADF - up to 215.9 x 863 mm
- Automatic
- 50 sheets
- Interfaces Details
- USB 2.0 , USB 2.0 (Host) - Type A
- Included Accessories
- Calibration paper, carrier sheet, plastic card carrier sheet
- Cables Included
- 1 x USB cable
- ENERGY STAR Certified
- Voltage Required
- Power Consumption Operational (Standby)
- 18 Watt
- Power Consumption Stand by
- 4 Watt
- Power Consumption Sleep
- 1.5 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 29.9 cm
- 22 cm
- 17.9 cm
- 3.3 kg
- 5 °C
- 35 °C
- 20 - 80%
- Sound Emission
- 49 dBA
