Rebirth of the cool
Finally, a USB mic that's not only easy to use, but sounds as good on your desktop as it does in a professional recording studio. Meet the Snowball; the world's first professional USB mic. Whether you're recording a guitar at your kitchen table or a complete band in the studio, the Snowball can capture it with detail unheard of before in a USB mic.
Works with the iPad!
Snowball and Snowflake can be used to record on iPad via Apple's camera connection kit (USB-to-30-pin) or the Lightning to USB camera adapter! Using these adapters, you can get Blue's studio-quality audio on your iPad with any recording app, including GarageBand.
The Snowball is a direct plug n' play mic that connects to either a Mac or PC - no additional software is needed. With its dual capsule design and unique three-pattern switch (cardioid, cardioid with -10dB pad and omni), the Snowball can handle everything from soft vocals to the loudest garage band - and it's ideal for podcasting.
Record studio-quality vocals, instruments, podcasts and more
Snowball USB microphones bring the same Blue heritage that powers elite studios and artists to your home setup, so you can achieve studio-quality sound on your desktop with ease. Snowball utilizes a unique dual capsule design to ensure rich, detailed sound for any project. -
It doesn't get any easier
Want to get studio-quality audio quickly and easily? Done. The Snowball family's excellent sound quality and easy operation make them the superior USB microphones for podcasting and desktop recording. -
Capture a variety of sources
The Snowball USB microphone is perfect for recording and streaming on your desktop. It gives you the flexibility and versatility to capture music, podcasts, game streams, and more in stunning sound quality.
- Blue Microphones Snowball - microphone
- Product Type
- Microphone
- Recommended Use
- Computer
- Gloss black
- Microphone
- External
- Microphone Technology
- Electret condenser
- Microphone Operation Mode
- Cardioid, omni-directional
- 2-year warranty
- Product Type
- Microphone
- 460 g
- Gloss black
- Recommended Use
- Computer
Microphone
- Connectivity Technology
- Wired
- Frequency Response
- 40 - 18000 Hz
- Connector Type
- USB
- Limited warranty - parts and labour - 2 years
