V7 Keyed Laptop Security Lock
Quicklinx: 6KMZWS00 Mfr#: SLK500-8E
The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
  • Fits 99% of notebook computers manufactured today
  • Compatible with all Kensington Security Slots
Security is on everyone's minds these days, and the V7 Keyed Laptop Security Lock offers a simple and effective way to secure your laptop or desktop PC, monitor or projector with a built-in lock slot.
Just wrap the sturdy cable around an immovable object, pass it through the slot and turn and remove the key. There are no combinations to remember, and you'll have peace of mind knowing you're securing important data as well as equipment.
  • Secure any laptop, desktop computer, monitor or projector with a built in lock slot; easy to install and use; includes 2 identical keys.
  • Colour Silver lock with black security cable
  • Cable Length 5 feet (1.5m)
  • Security Cable Galvanized steel wire core with plastic scratch preventative jacket
  • Cable Diameter 0.18" (4.5mm)
  • Lockhead Dimension 0.9" X 1.29" (23mm X 33mm)
  • Weight 0.27 lbs / 125 gr
  • Warranty Lifetime Warranty
