Speed up your PC multimedia experience. Upgrade from integrated graphics to the new NVIDIA® GeForce® GT 730 dedicated card and enjoy faster PC gaming, video, photos, and web.
- Dynamically enables vertical sync based on your current frame rates for the smoothest gaming experience.
- Designed to work perfectly with the new PCI Express 2.0 bus architecture, offering a future-proofing bridge to tomorrow's most bandwidth-hungry games and 3D applications by maximizing the 5GT/s PCI Express 2.0 bandwidth.
- Support for HDMI output enables sending both high-definition video and audio signals to an HDTV via a single cable.
- HDCP stands for High-Bandwidth Digital Content Protection, a copy protection scheme to eliminate the possibility of intercepting digital data midstream between the source to the display.
- Windows 7 is the next generation operating system that will mark a dramatic improvement in the way the OS takes advantage of the graphics processing unit (GPU) to provide a more compelling user experience.
- Able to drive the industry's largest and highest resolution flat-panel displays up to 2560 x 1600 and with support for HDCP.
- Full support for NVIDIA PhysX technology, enabling a totally new class of physical gaming interaction for a more dynamic and realistic experience with GeForce.
Spec
- Product Number NEAT7300HD06-2080H
- Memory Amount 1024MB
- Memory Interface 64bit
- DRAM Type DDR3
- Graphics Clock 902
- CUDA Cores 384
- Microsoft DirectX 12
- OpenGL 4.4
- Bus Support PCI-E 2.0 x 8
- Certified for Microsoft Windows 7 ?
- Certified for Microsoft Windows 8 ?
- Maximum Digital Resolution 2560x1600
- Maximum VGA Resolution 2048x1536
- Dual-Link DVI Yes
- VGA Yes
- HDCP Yes
- HDMI Yes
- Height 2 Slot
- PCB Width 115mm x 69mm
- Graphics Card Power 23 W
- Minimum Recommended System Power 300 W
- Accessory Manual, Driver Disc
