The NA-705 is an entry level range which meets the latest thermal requirements. The modern mesh front panel contains a filter behind it and the drive bays to keep dust out. Also includes a 500W ezcool PSU with SATA support and light up blue LED to front panel
- Fan Duct-3G fan duct
- Riveted 0.6mm Japanese SECC metal frame in metallic silver
- PSU- 500w with 1 x sata; 3 x molex
- Dimensions- W180D445H410mm
- CE-ROHS Compliant
- Manufacturer:Ezcool
- Audio Output: Y
- I/O Ports: 2 x USB 2.0
- Colour: Black
- Weight: 6200g
- Form Factor: ATX
- Supported Motherboard Form Factor: mATX / ATX
- Material: 0.6mm SECC metal
- Ventilation Fans: 1 x 80mm rear fan space; 1 x 80mm front fan space
- External Drive bays: 3 x 5.25
- Internal Drive bays : 1 x 3.5 ; 4 x 3.5 HDD
- This does not come with a power cable for the PSU
