Silent 120mm red fan with low noise technology <20dBA
Packaged in designer retail box
Quiet fan with thermal control
Black coated casing
24 pin; 4 Pin (12V); 1 x 6 pin PCI-e; 4 x Sata; 3 x 4 pin; 1 x FDD
Cable length 45cm
Meets Intel v2.03 enhanced +12V
230V with rear on/off power down button
Over-voltage and current protection +3.3V;+5V;+12V
100% Burn in and hipot tested; short circuit protection
EMI Filter built in
CE/ FCC/ UL approved
ROHS Compliant
+3.3V 24A; +5V 34A; +12V 38A; -12V 0.5A; +5VSB 2.0A
