The concept of Best Value is to offer customers the best value product, sourced from a variety of manufacturers all over the world, in any given category, at any point in time. The products selected for our Best Value range are carefully evaluated in terms of price, performance and manufacturing quality before they make it onto our website. Although certainly a 'value' brand, Best Value products are never inferior quality... just superb value for money.
FEATURES:
USB 2.0 and 1.1 compliant
High speed 480 Mbps data transfer speed
4 downstream type A USB ports provided
Enables a PC to connect to high speed devices
Supports both OHCI and EHCI, data transfer speed up to 480 Mbps
Supports self power mode
Supports Plug and Play
Connect up to 127 USB devices
- Cables Direct USB cable - 5 m
- USB cable
- Length
- 5 m
- Connector(s)
- 1 x 4 PIN USB Type A - male
- Connector(s) (Other Side)
- 1 x 4 PIN USB Type B - male
- USB / Hi-Speed USB
- USB cable
- Length
- 5 m
- Connector(s)
