Belkin VGA Monitor Replacement Cable
Customer rating: 4.0* (Write a review)
Quicklinx: 18MNWS00 Mfr#: F2N028B7.5M-GLD
Designed to interface any PC compatible computer to a VGA or SVGA monitor with HDDB15 female connectors. Featuring 24K gold plated corrosion-proof connectors for maximum conductivity.
Belkin Gold Series VGA cable - 7.5 m
VGA cable
Length
7.5 m
Connector
HD-15 (VGA) - male
Connector (Second End)
HD-15 (VGA) - male
Package Type
Retail
VGA cable
Shielding Material
Aluminium
Length
7.5 m
Connector
Package Type
Retail
Customer reviews
Write a review for the Belkin VGA Monitor Replacement Cable here!
Excellent cable!
Reviewed by Matt. Review Posted 17/06/2007
What can i say. I use this cable to connect my PC to my 50" rear projection tv using D-sub 15-pin to 15-pin. Perfect picture, no latnecy, quality at least ten times that of my old s-video connection. At 7.5m length with these features, you'd be silly to pass it by! Dabs delivery as always spot on and fast!
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Vga cable
Reviewed by Nick. Review Posted 19/01/2006
I brought this cable to connect to my tv. But found it to be very blurry as if you could see double. I then connected it to my comp monitor and got the same.on inspecting the cable against my orignal monitor cable found i found it to have 15 pin holes but only 14 were used up but my original used all 15 pin holes could not explain so i'm gonna return it.
  • Overall 2*
  • Ease of use 5*
  • Value for money 3*
The opinions expressed in this reviews section are those of our customers and not of BT Business Direct. Nothing contained herein amends BT Business Direct’s terms and conditions.
