Belkin OmniView PRO3 USB & PS/2 4-Port KVM Switch
Quicklinx: 4PJ9WS00 Mfr#: F1DA104ZEA
The OmniView PRO3 USB & PS/2 KVM Switch provides easy and dependable server control with extraordinary performance. The Switch enables network administrators to monitor and control up to 4 USB- and PS/2-platform servers from a single console. The PRO Series KVM Switches are the industry's most popular for small-to-medium server rooms, branch locations, and test and development labs. Designed to grow along with your server network, the Switch can be daisy-chained together using dedicated daisy chain ports with other OmniView PRO Series KVM or SMB KVM Switches with DB25 daisy-chain ports to support up to 256 servers.
Belkin OmniView PRO3 USB & PS/2 4-Port KVM Switch - KVM switch - 4 ports
KVM switch - 4 ports - stackable
Subtype
KVM
Ports
4 x KVM port(s)
On-Screen Display, firmware upgradable
27.9 cm x 15 cm x 4.5 cm
2.4 kg
SunSoft Solaris 8, Novell NetWare 5.x, Microsoft DOS 5.x or later, Apple MacOS X, Microsoft Windows Server 2003, Red Hat Linux 8.x, Microsoft Windows 95/98/ME/NT/2000/XP, Microsoft Windows 7, Microsoft Windows Vista
3-year warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
4 x KVM port(s)
Keyboard / Mouse Interface
PS/2, USB
Max Resolution
1920 x 1440 @ 75 Hz
Status Indicators
Port status
4 x KVM 50 pin Centronics , 2 x network stack device DB-25 , 1 x RJ-11 management , 1 x keyboard (PS/2) , 1 x mouse (PS/2) , 1 x keyboard (USB) Type A , 1 x mouse (USB) Type A , 1 x VGA HD-15
External power adapter
1 x serial cable
27.9 cm
15 cm
4.5 cm
2.4 kg
Limited warranty - 3 years
0 - 80%
Resources
The following resources are available for the Belkin OmniView PRO3 USB & PS/2 4-Port KVM Switch
