Belkin Headphones with Lightning Connector - Black
Quicklinx: FCWVWS00 Mfr#: G3H0001btBLK
Accessory Type: Headphones
Connectivity: Wired
Colour: Black
Hurry, only 1 left in stock!
£28.14 ex VAT
£33.76 inc VAT
With high-quality sound, supreme comfort and fit, and exceptional durability, ROCKSTAR headphones are the headphones for you. Packed with features, including water resistance and noise isolation, these compact headphones deliver superior audio without distraction - so you can lose yourself in music, be transported to a different world with an audio book, or experience the highs and lows of every story with compelling podcast content.
  • A perfect fit for a perfect sound
    Perfectly fitting headphones create a far superior sound. ROCKSTAR combines ear tips that can be tailored to your ear, with a design that actively directs the sound towards your eardrum. The result is excellent noise isolation, so you can be sure you are experiencing the music as the artist intended.
  • Comfort is music to your ears
    Earbuds are a main contributor to headphone discomfort. With differently sized ear tips provided with ROCKSTAR, it's easy to find the right fit for a more comfortable listening experience. Holding the ear tips, angled drivers reduce strain on your ear, so you can enjoy all-day comfort, and listen to the music you love, for as long as you like.
  • Sweat and splash resistant
    Wherever you listen to music, your ROCKSTAR headphones are designed to go with you. This is why they are made them sweat and splash resistant - making them ideal for all-weather use, as well as fitness or gym sessions.
Belkin ROCKSTAR - earphones with mic
Earphones - wired - Lightning
Compatibility
iPhone
Recommended Use
Portable electronics
Headphones Form Factor
In-ear
Wired
Sound Output Mode
Stereo
Noise Isolating
Microphone
On-cable
Controls
Volume, answer/end, play/pause, next/previous track
Apple 10.5-inch iPad Pro; iPad mini 4 (4th generation); iPhone 7, 7 Plus, 8, 8 Plus, X, XR, XS, XS Max
Compatibility
iPhone
Recommended Use
Protection
Splashproof, sweat-resistant, water-resistant
Audio Output
In-ear
Wired
Sound Output Mode
Stereo
Noise Isolating
In-Cord Volume Control
Microphone
On-cable
Remote Control
Controls
Connector Type
Headphones (Lightning)
Cable
Cable Length
1.12 m
3 pairs of silicone ear tips (small, medium, large)
Cable Details
Headphones cable - anti tangle - 1.12 m
MFI
Apple 10.5-inch iPad Pro , Apple iPad mini 4 (4th generation) , Apple iPhone 7, 7 Plus, 8, 8 Plus, X, XR, XS, XS Max
Connectivity: Wired
Colour: Black
Brand: Belkin
