Connect USB devices easily in tight workspaces. The Flexible USB Cable Adapter from Belkin lets you connect USB devices to your notebook or desktop computer in even the most cramped workspaces. This small, lightweight USB adapter has a flexible swivel connector that bends and rotates 180 degrees, so you can conveniently connect USB devices to adjacent ports. Its compact size and advanced functionality make it the ideal accessory to include inside your laptop case - a great solution for today's mobile professional.
Flexible design
The 180° rotation feature of the Belkin Flexible USB Cable Adapter ensures it can fit into tight spaces, making it perfect for cluttered workstations or behind furniture. -
Universal compatibility
Designed to connect with any PC, this USB adapter enhances your setup by providing an easy connection for all your USB Type-A devices.
- Belkin Flexible USB Cable Adapter - USB adapter - USB to USB
- USB adapter
- 180° rotation
- Connector
- 4 pin USB Type A - male
- Connector (Second End)
- 4 pin USB Type A - female
- Black
- USB adapter
- 180° rotation
- Black
- Connector
