Upgrade your network with a CAT6 Snagless Networking Cable from Belkin and enjoy clean, clear transmissions. Now you can replace CAT5 cables that don't support 100BASE-T or Gigabit Ethernet and improve the return loss in your current network by 40 percent. Engineered with 50-micron gold-plated connectors to ensure clear transmissions, and snagless molds to protect the RJ45 tabs from damage during installation, this cable meets and exceeds the performance requirements of Category 6.
Enhanced connectivity
The Belkin High Performance patch cable is designed with gold-plated RJ-45 connectors on both ends, ensuring a high-quality connection that minimizes signal loss and interference. Its CAT 6 specification allows for improved network speed, making it an ideal choice for demanding network environments. -
Reliable design
Featuring UTP (Unshielded Twisted Pair) technology and a T568A wiring scheme, this cable is built to provide a reliable, uninterrupted connection. The male-to-male configuration with a single RJ-45 connector on each end makes it easy to connect various network devices, from PCs to network switches.
- Belkin High Performance patch cable - 1 m - white
- Patch cable - CAT 6
- Technology
- Wiring Scheme
- T568A
- Molded, snagless
- Length
- 1 m
- Connector
- RJ-45 - male
- Connector (Second End)
- RJ-45 - male
- White
- Limited lifetime warranty
- Designed For
- Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch; OmniView SMB CAT5 KVM Switch
- Network Cable Type
- Technology
- Wiring Scheme
- T568A
- Plated Connector
- Gold
- Molded, snagless
- Length
- 1 m
- White
- Connector
- RJ-45 - male
- RJ-45 - male
- Designed For
- Belkin Omniview SMB 1x16 KVM-over-IP Switch, SMB 1x8 KVM-over-IP Switch , Belkin OmniView SMB CAT5 KVM Switch
