Belkin BOOST UP CHARGE 10000 mAh 18 Watt Fast Charge/PD USB-C Power Bank - Black
Quicklinx: G7G8WS00 Mfr#: BPB001btBK
Type: Rechargeable
More than 50 In Stock
£42.09 ex VAT
£50.50 inc VAT
Charge your USB-C devices fast with the Belkin BPB001btBK 10000 mAh Portable Power Bank. With the support of Power Delivery, you get up to 18 W output. That's enough to charge a smarthone halfway in just about half hour. Then there's an additional classic USB port for an extra device.
  • Long-lasting power for two devices
    The USB-C Power Bank 10K offers 10,000 mAh to provide up to an additional 36 hours of battery life to your smartphone. You can use the USB-C port to charge a phone quickly while using the USB-A port to charge a tablet, camera, or other device at the same time. A USB-C to USB-C cable is included, so you can start charging right out of the box.
  • Fast charge capable
    Featuring an 18W USB-C output with USB-C Power Delivery, you can fast charge your iPhone from 0 to 50% in 30 minutes and USB-C devices from 0 to 50% in around 36 minutes. Recharging the power bank is faster too. Just connect the USB-C port to recharge 40% faster than a standard 12W input.
Belkin BoostCharge power bank - USB, 24 pin USB-C - 18 Watt
Power bank
1.65 cm x 14.348 cm x 7.46 cm
Output Connector Type
Total 2: USB, 24 pin USB-C
Fast Charge Technology
Fast Charge, Power Delivery
10000 mAh
Power Provided
18 Watt
Cables
USB-C to USB-C cable - 15 cm
Power bank
Tablet, mobile phone
1.65 cm
14.348 cm
7.46 cm
Enclosure Colour
Output connectors
Total 2: 4 pin USB Type A, 24 pin USB-C
Power Provided
18 Watt
10000 mAh
Equipment Protection Value
2500 US Dollars
USB-IF, MFI
Type: Rechargeable
Brand: Belkin
