Rich, premium sound in a sleek, pocketable design.
Beats Studio Buds + deliver rich, premium sound in a pocketable design, wherever you go. Featuring powerful, balanced acoustics, Active Noise Cancelling, Transparency mode, high-quality calls, up to 36 hours of battery life, enhanced Apple and Android compatibility, and 4 ear tip options to ensure a custom fit and great sound.
Powerful, Balanced Sound
Beats Studio Buds + deliver rich, immersive sound whether you’re listening to music or taking calls. Each bud is equipped with a custom two-layer transducer that flexes to deliver cleaner bass and ultra-low distortion.
Three new acoustic vents improve audio precision and gently relieves pressure for a more comfortable all-day fit.
At the touch of a button, two dynamic listening modes let you choose whether to keep the world out or let it in. Active Noise Cancelling adapts to your personal fit, neutralizing unwanted external noise.
With 3x larger microphones, new venting, and a powerful processor, Beats Studio Buds + have up to 1.6x more active noise cancelling power.
Transparency Mode
Transparency mode blends your listening experience with the world around you. External-facing microphones capture ambient sound to mix in with your music when you need to be aware of your surroundings.
Beats Studio Buds + has up to 2x improved Transparency.
Surrounds You in Sound
Beats Studio Buds + support spatial audio for immersive music — delivering a surround sound experience — that you can take anywhere.
It's like being surrounded by 64 speakers at once.
All-Day Comfort
With four ear tip options (XS, S, M & L) to fit a wider range of ears, Beats Studio Buds + create a comfortable acoustic seal for the best listening experience, securing your earbuds in place.
More Music, Less Charging
With up to 36 hours of total listening time2 from the sleek, pocket-sized charging case, Beats Studio Buds + are ready to go whenever you are.
When battery is low, Fast Fuel gives up to 1 hour of playback with a 5-minute charge.
Crystal Clear Calls
3x larger microphones,1 powerful ANC, and a voice-targeting algorithm precisely filter background noise for crisp, clear call performance.
At Your Fingertips
Simple, customizable on-ear controls allow you to manage music, toggle listening modes, take calls and activate voice assistant using the ‘b’ button.
Easy to Use, Hard to Lose
Beats Studio Buds + offer a robust set of native Apple and Android features including: one-touch pairing, automatic switching, ‘always on’ voice assistance, and ‘Find My.’
Beats custom acoustic platform
Beats Studio Buds + custom acoustic platform packs powerful, balanced sound in a sophisticated, pocketable design. Reengineered acoustic venting improves audio precision and gently relieves pressure for a more comfortable all-day fit. Each bud is equipped with a two-layer transducer that flexes to deliver cleaner bass and ultra-low distortion. So whether you're listening to music or taking calls, Studio Buds + deliver rich, immersive sound wherever you go. -
Active Noise Canceling and Transparency Mode
At the touch of a button, two dynamic listening modes let you choose whether to keep the world out or let it in. Active Noise Canceling (ANC) has been engineered to adapt to your personal fit, neutralizing unwanted external noise. Easily switch to Transparency mode when you need awareness of the world around you. -
More music, less charging
With up to 36 hours of total battery life including 27 hours from the sleek, pocket-sized charging case and up to 9 hours from the earbuds, Beats Studio Buds + are ready to go whenever you are. Find yourself low on battery? A 5-minute Fast Fuel charge provides an hour of additional use² so you get more music, podcasts, and calls between every charge. -
Enhanced Apple and Android compatibility
Beats Studio Buds + offer a robust set of Apple and Android features including one-touch pairing and "Find My" device. -
One-touch pairing
Easy, one-touch setup instantly pairs with every device in your iCloud account. -
"Hey Siri"
Simply say "Hey Siri" to activate your voice assistant. -
Over-the-air updates
Receive software updates and features automatically. -
Audio Switch
Seamlessly transition audio between your Android, Chromebook, and other compatible devices.
- Beats Studio Buds + - true wireless earphones with mic
- Product Type
- True wireless earphones - Bluetooth
- Compatibility
- iPhone, iPad, iPod, Android phone, Mac, Android tablet
- Recommended Use
- Portable electronics
- Additional Functions
- Transparency mode
- Transparent
- Headphones Form Factor
- In-ear
- Wireless Technology
- Bluetooth
- Sound Output Mode
- Stereo
- Sound Effects
- Balanced Sound
- Active Noise Canceling
- Controls
- Multiple function button, ANC/transparency
- Intelligent Assistant
- Siri
- 1-year warranty
- Product Type
- True wireless earphones - Bluetooth - wireless
- Compatibility
- Transparency mode
- Dimensions & Weight Details
- Charging case: 5.1 cm x 7.2 cm x 2.55 cm / 49 g
- 1.85 cm
- 2.05 cm
- 1.5 cm
- 5 g
- Transparent
- Recommended Use
- Over the air updates, one-touch pairing
- Protection
- Sweat-resistant, IPX4, water-resistant
- Tracking Data
- Location
Audio Output
- In-ear
- Connectivity Technology
- Wireless
- Bluetooth
- Sound Output Mode
- Stereo
- Sound Effects
- Balanced Sound
- Active Noise Cancelling Technology
- Adaptive Noise Cancelling
- Fast Fuel technology, Google Fast Pair
Microphone
- Form Factor
- Built-in
Remote Control
- Controls
Internet of Things (IoT)
- Internet of Things (IoT) Compatible
- Siri
- Included Accessories
- Charging case, 4 pairs of ear tips (XS, S,M, L), USB-C to USB-C charging cable
- Cable Details
- USB-C to USB-C cable
- Bluetooth Class 1
- Battery
- Headphone battery rechargeable - Lithium Ion
- Run Time (Up To)
- 9 hour(s)
- Run Time Details
- Continuous playback (with included charging case): up to 36 hours , Continuous playback: up to 9 hours
- Limited warranty - 1 year
Used stock
What is used stock?
Accessories | Packaging | Functional | Software | Manuals | ||
Ref:
H8ZX 048601 Condition: Customer return - item has been opened but is in excellent condition |
£75.44 |
Legend
- This part of the stock item is present and in good condition
- This part of the stock item is not present or functional
- This part of the stock item is damaged in some way. This damage may not render this part of the stock unusable.
- This part of the stock item is not applicable e.g. it might not include accessories or software as standard
- This item has not been tested.
