The be quiet! Power Zone is home for discerning gamers and PC enthusiasts seeking high power, top performance and great features. Power Zone 850W hits that sweet spot with granite stability, advanced cooling features, low noise and great value.
850 Watts of continuous power output
850 Watts of continuous power output with massive 12V rail design and DC-to-DC technology make this power supply ideal for overclocking. -
Variable speed 135mm SilentWings fan
Variable speed 135mm SilentWings fan with airflow-optimized blades, copper core fluid dynamic bearing, and special 6-pole motor enables quiet operation. -
COOL OFF feature
COOL OFF feature runs fans for three minutes after system shutdown to protect your valuable components at their time of maximum heat stress. -
Connect up to three case fans
Connect up to three case fans for optimized system cooling that is thermally controlled by the PSU, quieting your whole system. -
Full cable management
Full cable management with quality sleeved cables and four PCI Express connectors supports maximum build flexibility and superior airflow in your case. -
80PLUS Bronze certification
80PLUS Bronze certification for high efficiency of up to 89%. Support of Intel's Deep Power Down C6/C7 mode.
- be quiet! Power Zone BN212 - power supply - 850 Watt
- Power supply - active Power Factor Correction (PFC) - internal
- Specification Compliance
- ATX12V 2.4/ EPS12V 2.92
- 80 PLUS Certification
- 80 PLUS Bronze
- 2.13 kg
- Input Voltage
- AC 100-240 V
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 850 Watt
- Output Current
- +3.3V - 25 A , +5V - 25 A , +12V1 - 70 A , -12V - 0.3 A , +5VSB - 3 A
- Output connectors
- 1 x power 24 pin ATX with detachable 4 pin section , 1 x power 8 pin +12V with detachable 4 pin section , 4 x 8 pin PCI Express power with detachable 2 pin section , 6 x 4 PIN internal power , 9 x 15 pin Serial ATA power , 4 x 8 pin PCI Express power with detachable 2 pin section , 1 x 4 PIN mini-power connector
- Modular Cable Management
- Cooling System
- 135 mm fan
- Included Accessories
- Cable ties, thumbscrews
- Black
- 15 cm x 17.5 cm x 8.6 cm
- Environmental Standards
- ENERGY STAR
- 5-year warranty
- PSU Form Factor
- ATX
- Black
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50 - 60 Hz
- Power Output Connectors Details
- Output Voltage
- +3.3, +5, ±12 V
- Power Capacity
- 850 Watt
- Output Current
- Efficiency
- 89%
- 80 PLUS Bronze
- Cables Included
- Power cable - external - 1.5 m
- MTBF
- 100,000 hours
- Cooling System
- 135 mm fan
- Overheat protection, over current protection, over voltage protection, overpower protection, SLI ready, undervoltage protection, dual 12V rails, temperature controlled fan, CrossFireX ready
- TUV, DEMKO, FIMKO, NEMKO, SEMKO, CB, RoHS, WEEE
Sustainability Information
- ENERGY STAR
- Limited warranty - 5 years
- 0 °C
- 50 °C
- 15 cm
- 17.5 cm
- 8.6 cm
- 2.13 kg
- Shipping Width
- 24.8 cm
- Shipping Depth
- 32.8 cm
- Shipping Height
- 10.2 cm
- Shipping Weight
- 2.36 kg
