B-Tech Double arm flat screen wall mount with tilt and swivel
Quicklinx: 7S9MWS00 Mfr#: BT7513/PB
Type: Mounting kit
10 In Stock
£51.18 ex VAT
£61.41 inc VAT
This mount is designed for LCD VESA standard screens with a screen size from 10" to 23" and weight up to 15kg. The BT7513 has a twin arm design that allows for full flexibility when mounting your screen - it can mount the screen flat to the wall or extend out to up to 450mm from the wall. There are three swivel points - one at the wall for 180º, one in the middle of 240º and one at the screen of 240º - this makes it possible to mount your screen in the most inconvenient of locations such as in corners. The BT7513 also has a tilt function of up to +/- 17º.
B-TECH BT7513 - mounting kit - Tilt & Swivel - for flat panel - black
Mounting kit (Tilt & Swivel) - wall-mountable
Mounting Components
Articulating arm, wall mount
Recommended Use
Flat panel
Recommended Display Size
Up to 23"
VESA Mounting Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
15 kg
AV Furniture
Mounting kit
Mounting Components
Design
Tilt & Swivel
Recommended Use
Flat panel
Placing / Mounting
Wall-mountable
Up to 23"
Max Load Weight
15 kg
Type: Mounting kit
Brand: B-Tech
