Active splitters separate data and power coming over a network cable. They enable Axis network video products that lack built-in support for Power over Ethernet to receive both power and data from a network connection.
- AXIS - PoE splitter
- PoE splitter - external
- 100 g
- Output Voltage
- 5 V
- Input Connectors
- RJ-45
- Output connectors
- 1 x power DC jack
- 5.5 cm x 8.1 cm x 2.5 cm
- Designed For
- Network Camera 206, 206M, 207
- Input Connectors
- RJ-45
- Power Output Connectors Details
- 1 x power DC jack
- Output Voltage
- 5 V
- 1 x LAN - RJ-45
- EN55024, EN55022 Class A, CISPR 22, FCC Part 15 B
- 0 °C
- 40 °C
- 10 - 90%
- 5.5 cm
- 8.1 cm
- 2.5 cm
- 100 g
- Designed For
- AXIS Network Camera 206, 206M, 207
