The 17-inch LCD rack console and integrated KVM switches create a single, integrated access solution for SMB and server room environments. These solutions provide optimal support of PS/2 and USB systems. Out-of-band access to critical servers is non-intrusive to the network and reduces downtime.
- Avocent LCD Console and KVM over IP Switch Integrated Tray - KVM console - 17"
- KVM console - 17"
- KVM Switch
- USB - 8 ports
- Keyboard, touchpad, 8 port KVM switch
- Native Resolution
- 1280 x 1024 at 60 Hz
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- 16.7 million colours
- Input Connectors
- VGA
- Voltage
- AC 120/230 V
- 44.5 cm x 65.1 cm x 4.4 cm
- Height (Rack Units)
- 1U
- 12.8 kg
- Localisation
- United Kingdom
- UL, VCCI, BSMI, GOST, GS, NOM, CB, EMC, FCC, ULC, RoHS, KCC
- Display Type
- KVM console / TFT active matrix
- Diagonal Size
- 17"
- Built-in Devices
- 8 port KVM switch
- Native Resolution
- Brightness
- 250 cd/m²
- Contrast Ratio
- 1000:1
- Colour Support
- 1U
- 12.8 kg
Input
KVM
- KVM switch - 8 ports
- Keyboard / Mouse Interface
- USB
- Keyboard (USB) , Mouse (USB) , VGA , USB , 8 x KVM (RJ-45)
- Rack Mounting Kit
- Included
- MTBF
- 50,000 hour(s)
- Localisation
- United Kingdom
- Input Voltage
- AC 120/230 V
- Power Consumption (Typical)
- 33 Watt
- 0 °C
- 50 °C
- 0 - 80%
