The AVerVision SPB350+ is a high quality, yet affordable, platform visualize designed for budget conscious users who still require abundant features and functions. Featuring 30fps full motion high definition 1080p video output, users are able to take advantage of the clarity of HD monitors and projectors. Images can be captured to the document camera itself, an SD card, or directly to a PC or MAC. The built-in 4"x 5" lightbox allows for the display of slides, negatives, or other transparent documents. The AVerVision SPB350+ is the perfect high-value visualize solution for virtually any display application.
- AVer AVerVision SPB350+ - digital document camera
- Digital document camera
- 47.8 cm x 38.1 cm x 50.5 cm
- 5.6 kg
- Connectivity Technology
- Wired
- Camera
- Colour - 650 TVL
- Optical Zoom
- 12 x
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Optical Sensor Type
- CMOS - 1/2.5" - 5 MP
- Focal Length
- 6 mm - 60 mm
- Focus Adjustment
- Automatic, manual
- Lens Iris
- F/3.5
- USB, S-Video, composite video, VGA, DVI
- Manual white balance, picture-in-picture capability, digital image freeze, SD-card slot, built-in LED lights, auto white balance
- 5-year warranty
- Wired
- 47.8 cm
- 38.1 cm
- 50.5 cm
- 5.6 kg
Camera
- Horizontal Resolution (TV Lines)
- 650
- Max Digital Video Resolution
- 1920 x 1080
- Digital Zoom
- 8
- Frame Rate (max)
- Still Image Capture Resolution
- 1920 x 1080
Image Sensor
- 5 MP CMOS 1/2.5"
Lens Construction
- Optical Zoom
- 12 x
- Focal Length
- 6 mm - 60 mm
- Lens Iris
- F/3.5
- Focus Adjustment
- Automatic, manual
- Video
- S-Video, composite video, VGA, DVI
- Computer Interface
- USB
- 1 x display / video - composite video/S-video output , 1 x display / video - VGA output - 15 pin HD D-Sub (HD-15) , 2 x display / video - VGA input - 15 pin HD D-Sub (HD-15) , 1 x USB , 1 x display / video - composite video output - RCA , 1 x display / video - DVI-Analog/Digital , 1 x network - RS-232
- Included Accessories
- Remote control, dust cover
- Software Included
- AVer+ Software
- Limited warranty - 5 years
