The F50 is many tools in one. A scanner, a web-video-digital camera, lined-graph-plain paper and with "best-in-class image clarity" you can see clearly with every single action.
Megapixels; Mega images; Mega wows
Learning becomes wonderment when it's unfolding on the big screen and nothing puts on a show like the 5 megapixels of the F50 doc cam that's primed to show crisp text, bright images and vivid colors. The F50 is also engineered with a large imaging sensor to collect lots of light. More megapixels and more light mean better resolution and gorgeous detail for showcasing your classroom's best. -
Zoom into it
Really get down to the nitty-gritty details of your experiment, math problem or poem. With 80x zoom, you can zero in on the smallest details and clearly see the big picture. So that tiny 1/8 or 1/16 of an inch on a ruler can be clearly seen by the student in the back of the class. A bonus is that when you are in digital zoom, you can move around the image while you are still zoomed in. -
See micro worlds in action
With the F50's optional microscope adaptor, you can explore nature's tiniest communities in action. Simply fit the adaptor to any standard microscope eye-piece and you can now display small worlds on big screens. -
Shed some light
Usually when the projector is on, the lights are off. Since the F50 is connected to a projector, it has built-in LED lights in the camera head to illuminate and display the objects underneath beautifully. -
Make a point
Need to explain a tricky concept or emphasize a key point? By simply plugging in an USB mouse into the F50, you can easily add annotations, highlights, arrows and captions. You don't need a computer. Easy peasy.
- AVer AVerVision F50 - digital document camera
- Digital document camera
- Audio
- Yes: built-in microphone
- 38 cm x 20 cm x 54 cm
- 2.5 kg
- Connectivity Technology
- Wired
- Camera
- Colour - 700 TVL - NTSC, PAL
- Optical Zoom
- 2 x
- Max Resolution
- 1920 x 1080
- Frame Rate (max)
- 30 frames per second
- Optical Sensor Type
- CMOS - 1/2.5" - 5 MP
- Focus Adjustment
- Automatic, manual
- USB 2.0, composite video, VGA, DVI
- Cables Included
- 1 - USB cable - external , 1 - video / serial cable - external , 1 - VGA cable - external , 1 - video cable - external
- Manual white balance, picture-in-picture capability, manual exposure, remote control, digital image rotation, digital image freeze, auto exposure control, adjustable self timer, image mirror, built-in LED lights, SDHC-card slot, negative conversion, image split, 1.25x AVERZOOM, auto white balance
- Audio Support
- Wired
- 38 cm
- 20 cm
- 54 cm
- 2.5 kg
Camera
- Video Format
- NTSC, PAL
- Horizontal Resolution (TV Lines)
- 700
- Max Digital Video Resolution
- 1920 x 1080
- Digital Zoom
- 8
- Frame Rate (max)
- Still Image Capture Resolution
- 1920 x 1080
Image Sensor
- 5 MP CMOS 1/2.5"
Lens Construction
- Optical Zoom
- 2 x
- Focus Adjustment
- Automatic, manual
- Video
- Composite video, VGA, DVI
- Computer Interface
- USB 2.0
- 1 x display / video - VGA input - 15 pin HD D-Sub (HD-15) , 1 x display / video - VGA output - 15 pin HD D-Sub (HD-15) , 1 x serial / video - RS-232/composite video output , 1 x microphone - input - mini-phone 3.5 mm , 1 x USB 2.0 - 4 pin USB Type A , 1 x audio - output - mini-phone 3.5 mm , 1 x USB 2.0 , 1 x display / video - DVI-Analogue/Digital output - 24+5 pin combined DVI
- Included Accessories
- Carrying case, remote control, anti-glare sheet
- Cables Included
- 1 x USB cable - external , 1 x video / serial cable - external , 1 x VGA cable - external , 1 x video cable - external
- FCC, RoHS
- Power Device
- Power adapter - external AC 120/230 V (50/60 Hz)
- Software Included
- Drivers & Utilities
- OS Required
- Microsoft Windows XP SP2, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Apple MacOS X Lion 10.7
