Asus XTION MOTION SENSOR FOR PC
Quicklinx: 82YFWS00 Mfr#: XTION/B/EU
Make your own motion-sensing software, only with the ASUS Xtion PRO! The world's first and only professional PC motion- sensing software development kit features OPNI NITE SDK middleware compatibility, making development a cinch. Create games, applications or whatever your creativity muscles can muster! Once you're done with the masterpiece, you can even sell it on the upcoming ASUS@vibe online entertainment content store and make some money!
  • Worldwide exclusivity
    It is the world's first and exclusive professional PC motion sensing development solution. You can make your fantastic ideas come true and introduce a better future to the public.
  • Especially designed for developers to create various applications
    The Xtion PRO development solution allows developers to apply the motion-sensing technology in various applications and industries to stand out from the competition. For example: Electronic Kanban is an ideal application for this technology and can be used widely for marketing, guidance or tourism and so on. Physical rehabilitation is also a good field for body detection applications. There are a number of fields that could benefit from motion-based technology, such as education, medical, conferences, games and many more.
  • Two function systems to make development easy
    Xtion PRO uses Infrared sensor and adaptive depth detection technology to capture users' real-time body movements, making body tracking more precise. The Xtion PRO development solution comes with a set of developer tools to make it easier for developers to create their own gesture-based applications without the need to write complex programming algorithms.
  • Easy to use
    The Xtion PRO features an easy plug and play USB design, with the Xtion PRO development solution OPNI NITE middleware compatible.
Asus Xtion PRO - motion sensor - wired
Motion sensor
Wired
Video conferencing, OpenNI
Motion sensor
Wired
USB
1 x USB 2.0
Linux, Microsoft Windows Vista (32/64 bits), Linux (64-bit), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Ubuntu 10.10
USB cable (1.7 m)
17.8 cm
3.8 cm
4.8 cm
