Asus RAMPAGE V EXTREME/U3.1 S2011 Intel X99 DDR4 USB3.1 Bundled
Quicklinx: B62BWS00 Mfr#: RAMPAGE V EXTREME/U3.1
  • IEEE 802.11n
  • Bluetooth 4.0
Most powerful X99 motherboard with OC Panel and USB 3.1 Type-A (Dual) card bundled
  • Intel® Core™ i7 processors on LGA 2011-v3 socket
  • Intel X99 Express chipset
  • OC Socket, OC Panel, Safe Boot and ReTry buttons - Powerful tuning kit for breaking records
  • Extreme Engine Digi+ IV - Primo components for rock-steady power
  • DirectCU, X-Socket II, multiple thermal sensors and Fan Xpert 3 - Stay even cooler
  • PCI Express 3.0 x4 M.2, dual SATA Express, 3T3R 802.11ac Wi-Fi - Unparalleled connectivity with blistering-fast transfer speeds
  • SupremeFX 2014, Sonic Radar II, Intel Ethernet, LANGuard, GameFirst III, KeyBot, RAMDisk - Hear more, banish lag, accelerate loading and control
  • USB 3.1 Type-A Card (Dual) bundled
  • Perfect spacing and PCI Express 3.0 speed for incredible graphics
    Unleash the full power of multiple graphics cards for visuals that never stutter, with just the right amount of space between each card. Onboard switches let you selectively enable or disable cards in a flash - configuring multi-GPU setups has never been easier!
  • Drive CPU and DDR4 performance beyond the limits
    Designed to break performance barriers, ASUS OC Socket utilizes extra pins to connect a proprietary circuit to contacts found on Haswell-E's land grid array (LGA). This feature enables higher DDR4 memory frequencies, lower latencies and enhanced stability while overclocking, extending all the way to extreme overclocking conditions, such as Liquid Nitrogen (LN2).
  • Cache Bus voltage adjustment
    Cache bus links areas such as CPU cores, DDR4 Memory Controllers, System Agent and the shared L3 Cache. It is a critical interconnect for the whole CPU subsystem. Higher Cache Bus frequency directly gives faster total sub-system performance. ASUS OC Socket exclusively provides an adjustable cache bus voltage to reach higher cache bus frequencies.
  • Optimized for extreme overclocking
    This is the first platform to support DDR4 memory, and it is capable of overclocking memory up to DDR4 3300+ MHz with all eight DIMMs fully loaded! ASUS-exclusive T-Topology circuit design plus patent-pending OC Socket unleash the full potential of DDR4 by minimizing crosstalk and signal reflections. Signal timing issues are also greatly reduced, resulting in improved stability and overall performance. ASUS works with almost every DDR4 memory vendor to ensure good compatibility - so you're assured reliable performance from your favorite brands.
  • Intuitive overclocking command center
    Get your hands on real-time system monitoring and tweaking in two modes. For both, a clear 2.6-inch display keeps you informed and in full control - so you can maximize the available power!
  • Save more time, break more records
    ROG understands overclockers better than any other manufacturer - so Rampage V Extreme includes hardware-level Safe Boot and ReTry buttons to help put things right when overclocking adventures go wrong. They're quick, easy and real time-savers!
  • Pump up your power
    An extreme platform demands extreme control over the purest power, and nothing delivers more control or purer power than Extreme Engine Digi+ IV - Rampage V Extreme's exclusive voltage-regulator module (VRM). MicroFine alloy chokes lower overall core loss for lower temperatures. This chip integrates the driver, high-side and low-side MOSFETs and features RDS On current-sensing technology. Extreme Engine Digi+ IV's high-frequency pulse-width modulation (PWM) implementation scales to 1MHz allowing the DRAM VRM to achieve a 40% increase in stability!
  • Copper-cooled to the core
    Exclusive DirectCU cooling technology puts better conductive copper heat-pipes in direct contact with Rampage V Extreme's Extreme Engine Digi+ IV VRM zone to provide incomparable heat dissipation. Other designs merely prevent overheating - Rampage V Extreme with DirectCU goes up to 7 degrees cooler.
  • Advanced fan controls for ultimate cooling and quietness
    Rampage V Extreme has 8 x 4/3-pin (PWM/DC) combo fan connectors, four intelligent onboard sensors plus three additional 2-pin headers and a selection of three thermal cables to help you monitor the temperatures of up to seven motherboards or key components in real time - so you're able to adjust CPU and case coolers automatically or manually for a good dissipation.
  • Scan and detect to dominate
    Designed for first-person shooters (FPS), Sonic Radar II displays a stealthy overlay that shows what opponents and teammates are up to. See the precise direction and origin of in-game sounds such as gunshots, footsteps and call-outs, and practice your enemy-pinpointing skills - and exclusive Audio Enhancement further improves in-game sound for superb hearing awareness. The Sonic Radar II includes a redesigned control panel with customizable game list!
ASUS RAMPAGE V EXTREME/U3.1 - motherboard - extended ATX - LGA2011-v3 Socket - X99 - with ASUS USB 3.1 Type-A CARD
Motherboard - extended ATX
Chipset Type
Intel X99 Express
Processor Socket
1 x LGA2011-v3 Socket
Compatible Processors
Core i7, Xeon E5-2600 v3 series, Xeon E5-1600 v3 series
Max RAM Size
64 GB
RAM Supported
8 DIMM slots - DDR4, non-ECC, unbuffered
Storage Ports
8 x SATA-600 (RAID), 2 x SATA Express port, 1 x M.2
USB / FireWire Ports
10 x USB 3.0 + 2 x USB 2.0 + (4 x USB 3.0 + 4 x USB 2.0 via headers)
Audio
HD Audio (8-channel)
LAN
Bluetooth, Gigabit Ethernet, 802.11a/b/g/n/ac
Bundled with
Motherboard - extended ATX - with ASUS USB 3.1 Type-A CARD
Chipset Type
Intel X99 Express
Processor Socket
LGA2011-v3 Socket
Max Processors Qty
1
Supported RAM
Max Size
64 GB
DDR4
Bus Clock
2133 MHz, 2800 MHz (O.C.), 2666 MHz (O.C.), 2400 MHz (O.C.), 3000 MHz (O.C.), 3300 MHz (O.C.)
Supported RAM Integrity Check
Non-ECC
Registered or Buffered
Unbuffered
Intel Extreme Memory Profiles (XMP), quad channel memory architecture
Audio
Audio Codec
SupremeFX
DTS Connect, High Definition Audio
LAN
Network Interfaces
Expansion Slots
1 x CPU , 8 x DIMM 288-pin , 4 x PCIe 3.0 x16 (dual x16 mode; triple: x16, x8, x8 mode; quad: x16, x8, x8, x8 mode; single card: x16 mode) , 1 x PCIe 2.0 x16 (x4 mode) , 1 x PCIe 2.0 x1
Storage Interfaces
SATA-600 -connectors: 8 x 7pin SATA, 1 x M.2, 1 x SATA Express port - RAID 0 / RAID 1 / RAID 10 / RAID 5 , SATA-600 -connectors: 1 x SATA Express port
1 x LAN (Gigabit Ethernet) , 2 x USB 2.0 , 10 x USB 3.0 , 1 x PS/2 keyboard / mouse , 1 x TOSLINK , 1 x audio line-out - mini-jack , 1 x audio line-in - mini-jack , 1 x microphone - mini-jack , 1 x audio line-out (rear) - mini-jack , 1 x audio line-out (center/subwoofer) - mini-jack
Internal Interfaces
4 x USB 2.0 - header , 4 x USB 3.0 - header , 1 x Thunderbolt - header , 1 x audio - header
Power Connectors
4-pin ATX12V connector, 24-pin main power connector, 8-pin ATX12V connector
BIOS Type
AMI
BIOS Features
WfM 2.0 support, Multilingual BIOS, ASUS EZ Flash 2, USB BIOS Flashback, UEFI BIOS, SMBIOS 2.7 support, DMI 2.7 support, ACPI 5.0 support, SMBIOS 2.8 support
Sleep / Wake Up
Wake on LAN (WOL), wake on PME
Hardware Features
C.P.R. (CPU Parameter Recall), jack retasking, MemOK!, NVIDIA SLI Technology Support, ASUS Q-Design, ROG Connect, ESD Guards, Q-DIMM, ASUS EZ DIY, Q-LED, Q-Slot, ProbeIt, CrashFree BIOS 3, ASUS Q-Connector, audio jack detect technology, ASUS CPU Level Up, ASUS EPU (Energy Processing Unit), ASUS COP EX, ASUS Q-Shield, NVIDIA 3-way SLI Technology Support, ASUS Extreme Tweaker, Intel Extreme Memory Profile (XMP) support, ASUS iROG, Intel Turbo Boost Technology 2.0, ASUS TPU (TurboV Processing Unit), GPU.DIMM Post, Loss-less content protection technology, ROG BIOS Print, ROG CPU-Z, NVIDIA 4-way SLI Technology Support, Voltiminder LED II, Q-Code, SupremeFX Shielding technology, AMD CrossFireX technology support, AMD 3-way CrossFireX technology support, ASUS DIGI+ Power Control, Onboard Button, ASUS USB Charger+, ASUS Wi-Fi GO!, AMD 4-way CrossFireX technology support, DirectKey, Disk Unlocker, ASUS Enhanced DRAM Overcurrent Protection, ASUS SSD Secure Erase, Preboot eXecution Environment (PXE), Clear CMOS Button, ELNA Audio Capacitors, ASUS Fan Xpert 3, Dual Intelligent Processors 5, GameFirst III, LANGuard, Sonic Radar II, Sonic Studio, Sonic SenseAmp, Sonic SoundStage, KeyBot, ASUS Extreme Engine Digi+ IV, USB 3.1 Boost
ROG connect cable, ROG OC Panel Kit, ROG Door Hanger, ASUS 3T3R Wi-Fi moving aerials
10 x Serial ATA cable , 1 x SLI bridge , 1 x 3-way SLI bridge , 1 x 4-way SLI bridge , 1 x CrossFire cable
Software Included
Kaspersky Anti-Virus, ASUS EZ Flash 2, ASUS AI Charger+, ROG CPU-Z, ROG Mem TweakIt Utility, DAEMON Tools Pro Standard, ASUS WebStorage, ASUS AI Suite III, ROG RAMDisk, ASUS HomeCloud, ASUS Turbo App, ROG GameFirst III
Plug and Play, ACPI 5.0
30.5 cm
27.2 cm
