ASUS STRIX GTX™ 980 Ti delivers truly elite gaming experience
- 1317MHz GPU boost clock in OC mode with 7200MHz factory-overclocked memory speed for outstanding gaming experience.
- DirectCU III with Patented Triple Wing-Blade 0dB Fan Design delivers maximum air flow with 30% cooler and 3X quieter performance.
- AUTO-EXTREME Technology with 12+2 phase Super Alloy Power II delivers premium delivers premium quality and best reliability.
- Pulsating STRIX LED makes a statement while adding style to your system.
- STRIX GPU-Fortifier relieves physical stress around the GPU in order to protect it.
- GPU Tweak II with Xsplit Gamecaster provides intuitive performance tweaking and lets you stream your gameplay instantly.
BLAZING-FAST. ARMOR-PROTECTED. SUPER-COOL.
Taken from the ancient Roman and Greek word for owl, Strix means the keenest hearing and sharpest eyesight. Strix means feeling your environment so that you detect and react to the slightest movement. Strix means survival on the very edge of instinct. Strix is in your blood, as it is in ours.
ASUS STRIX GTX 980 Ti gaming graphics cards packed with exclusive ASUS technologies, including DirectCU III with Triple Wing-Blade 0dB Fan Design for maximum air flow with 30% cooler and 3X quieter performance. This card features exclusive ASUS AUTO-EXTREME Technology with Super Alloy Power II for premium quality and best reliability. It also has GPU Tweak II with Xsplit Gamecaster, provides intuitive performance tweaking and lets you stream your gameplay instantly.
GAME COOL
DirectCU III with Dual 10mm Heatpipe
30% Cooler and 3X Quieter Performance
Exclusive DirectCU III cooling technology features two exclusive 10 mm direct-GPU contact heat-pipes that transports 40% more heat away from the GPU and outperform reference designs, achieving up to 30% cooler gaming performance.
PLAY SILENT
Patented Triple Wing-Blade 0dB Fans
Max Air Flow with 105% More Air Pressure
DirectCU III features triple 0dB fans engineered with a patented, new wing-blade design that delivers maximum air flow and improved 105% static pressure over the heat sink, while operating at 3X quieter volumes than reference cards. The 0dB fans also let you enjoy games like League of Legends® and StarCraft® in complete silence — because the fan stops completely when the GPU temperature remains below a set level*. This makes DirectCU III the coolest and quietest graphics card in the market.
PREMIUM QUALITY AND BEST RELIABILITY
All ASUS graphics cards are now produced using AUTO-EXTREME Technology, an industry-first, 100% automated production process that incorporates premium materials to set a new standard of quality. AUTO-EXTREME Technology ensures consistent graphics card quality as well as improved performance and longevity. This new manufacturing process is also environmentally friendly, eliminating harsh chemicals and reducing power consumption by 50%.
GAME YOUR WAY
GPU Tweak II with XSplit Gamecaster
Tweak Till Your Heart's Content
Redesigned with an intuitive, all-new UI, GPU Tweak II makes overclocking easier and more visual than ever, while still retaining advanced options for seasoned overclockers. With one click, the new Gaming Booster function maximizes system performance by removing redundant processes and allocating all available resources automatically. XSplit Gamecaster lets you easily stream or record your gameplay right from a convenient, in-game overlay.
All ASUS graphics cards are now produced using AUTO-EXTREME Technology, an industry-first, 100% automated production process that incorporates premium materials to set a new standard of quality. AUTO-EXTREME Technology ensures consistent graphics card quality as well as improved performance and longevity. This manufacturing process is also environmentally friendly, eliminating harsh chemicals and reducing power consumption by 50%. -
14-phase Super Alloy Power II
ASUS engineers have integrated premium components into their graphics card designs to reinforce overall reliability. Super Alloy Power II components greatly enhance efficiency, reduce power loss, provide 2X reduced component buzzing while under full load, and achieve thermal levels that are approximately 50% cooler than previous designs. -
Redesigned with an intuitive, all-new UI, GPU Tweak II makes overclocking easier and more visual than ever, while still retaining advanced options for seasoned overclockers. With one click, the Gaming Booster function maximizes system performance by removing redundant processes and allocating all available resources automatically. XSplit Gamecaster lets you easily stream or record your gameplay right from a convenient, in-game overlay. -
Armor protection
An advanced backplate prevents PCB bending over time, and now includes STRIX GPU-Fortifier, which relieves physical stress around the GPU in order to protect it.
- ASUS STRIX-GTX980TI-DC3OC-6GD5-GAMING - graphics card - GF GTX 980 Ti - 6 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 980 Ti
- Memory
- 6 GB GDDR5
- Core Clock
- 1216 MHz
- Boost Clock
- 1317 MHz
- CUDA Cores
- 2816
- Effective Memory Clock
- 7.2 GHz
- Memory Interface
- 384-bit
- Max Resolution
- 4096 x 2160
- DVI-I , HDMI , 3 x DisplayPort
- API Supported
- OpenGL 4.5
- 3.98 cm x 30.5 cm x 15.22 cm
- Microsoft Certification
- Compatible with Windows 7
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1216 MHz
- Boost Clock
- 1317 MHz
- CUDA Cores
- 2816
- Max Resolution
- 4096 x 2160
- API Supported
- OpenGL 4.5
- Super Alloy Power II technology, AUTO-EXTREME technology, 12+2 Phase Power Design, STRIX GPU-Fortifier, DirectCU III with Triple Wing-Blade 0dB Fan Design, HDCP
- Size
- 6 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 7.2 GHz
- Bus Width
- 384-bit
- Additional Requirements
- Dual-width x16 graphics slot, two 8-pin power connectors
- 375 Watt
- Included Accessories
- STRIX Laser Sticker
- Software Included
- Drivers & Utilities, XSplit Gamecaster, ASUS GPU Tweak II
- 3.98 cm
- 30.5 cm
- 15.22 cm
