Asus GeForce GTX 980 4GB PCI-E 3.0 HDMI DirectCU II OC STRIX
Quicklinx: 9TRRWS00 Mfr#: STRIX-GTX980-DC2OC-4GD5
  • NVIDIA GeForce GTX 980
  • DisplayPort
  • High-Definition Multimedia Interface (HDMI)
STRIX-GTX980-DC2OC-4GD5: ASUS Strix GeForce GTX 980 with factory-overclocked core delivers cool and silent gaming experiences
  • 1279 MHz Boost clock for better performance and outstanding gaming experience.
  • DirectCU II with 0dB fan technology lets you enjoy light games in complete silence, and hardcore gaming 30% cooler with 3X-quieter performance!
  • DIGI+ VRM with 10-phase Super Alloy Power delivers precise digital power for superior efficiency, reliability, and performance.
  • GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface.
  • GPU Tweak Streaming share on-screen action in real time so others can watch live as games are played.
Taken from the ancient Roman and Greek word for owl, Strix means the keenest hearing and sharpest eyesight. Strix means feeling your environment so that you detect and react to the slightest movement. Strix means survival on the very edge of instinct. Strix is in your blood, as it is in ours.
ASUS Strix GTX 980 gaming graphics card is factory-overclocked at 1279 MHz and packed with exclusive ASUS technologies, including DirectCU II to deliver cooler, quieter, and faster performance for incredible action gaming experiences. Strix GTX 980 also features 0dB fan technology to let gamers enjoy total silence during light gameplay as well as Blu-ray movie playback free from distracting background noise. Strix GTX 980 features exclusive ASUS DIGI+ VRM with 10 -phase Super Alloy Power components for enhanced durability and cooling, and GPU Tweak for overclocking and online streaming.
DirectCU II with 0dB Fan Technology - 30% cooler. Silent gaming.
Exclusive DirectCU II cooling technology outperforms reference designs with an exclusive 10mm heatpipe that transports 40% more heat away from the GPU -- a first for the industry! The design also includes 220%-larger heat-dissipation: this means performance that's 30% and three-times (3X) quieter than reference for ultra-stable hardcore gaming with very low noise. And Strix ups the ante still further with 0dB fan technology that lets you enjoy games like League of Legends® and StarCraft® in complete silence -- because the fan stops completely when the GPU temperature remains below a set level.
DIGI+ VRM with Super Alloy Power: 30% less power noise and 2.5X greater durability
Acclaimed DIGI+ VRM has been applied via a 10-phase power design that uses digital voltage regulators to minimize power noise by 30%, enhance power efficiency by 15%, widen voltage modulation tolerance, and improve overall stability and longevity by 2.5 times over reference.
GPU Tweak with Streaming: Real-time intuitive graphics tuning
  • Shows detailed specs and actual card status with GPU-Z
  • Monitoring widget provides real-time detailed multi-parameter info
  • Automatically checks and updates drivers and BIOS versions
Stream online instantly
GPU Tweak streaming tool that lets you share on-screen action in real time - so others can watch live as games are played. It's even possible to add to the streaming window scrolling text, pictures and webcam images
  • Graphics Engine: NVIDIA GeForce GTX 980
  • Bus Standard: PCI Express 3.0
  • Video Memory: GDDR5 4GB
  • GPU Boost Clock : 1279 MHz
  • GPU Base Clock : 1178 MHz
  • CUDA Core: 2048
  • Memory Clock: 7010 MHz ( MHz GDDR5 )
  • Memory Interface: 256-bit
  • Interface: DVI Output : Yes x 1 (DVI-I), HDMI Output : Yes x 1 (HDMI 2.0), Display Port : Yes x 3 (Regular DP)
  • HDCP Support : Yes
  • Power Consumption: up to 300Wadditional 6+8 pin PCIe power required
  • Accessories: 1 x Power cable
  • Software: ASUS GPU Tweak & Driver
  • Dimensions: 11.36 " x 5.3 " x 1.61 " Inch, 28.86 x 13.44 x4.09 Centimeter
  • Silent gaming
    Exclusive DirectCU II cooling technology outperforms reference designs with an exclusive 10mm heatpipe that transports more heat away from the GPU! The design also includes larger heat-dissipation: this means performance that's quieter than reference for ultra-stable hardcore gaming with very low noise. And Strix ups the ante still further with 0dB fan technology that lets you enjoy games like League of Legends and StarCraft in complete silence - because the fan stops completely when the GPU temperature remains below a set level.
  • Stream online instantly
    GPU Tweak streaming tool that lets you share on-screen action in real time - so others can watch live as games are played. It's even possible to add to the streaming window scrolling text, pictures and webcam images.
  • Real-time intuitive graphics tuning
    It shows detailed specs and actual card status with GPU-Z. Monitoring widget provides real-time detailed multi-parameter info. The card automatically checks and updates drivers and BIOS versions.
ASUS STRIX-GTX980-DC2OC-4GD5 - graphics card - GF GTX 980 - 4 GB
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
4 GB GDDR5
Core Clock
1178 MHz
Boost Clock
1279 MHz
CUDA Cores
2048
Effective Memory Clock
7.01 GHz
Memory Interface
256-bit
DVI-I , 3 x DisplayPort , HDMI
4.09 cm x 28.86 cm x 13.44 cm
Microsoft Certification
Compatible with Windows 7
3-year warranty
Graphics card
Bus Type
PCI Express 3.0 x16
Graphics Engine
Core Clock
1178 MHz
Boost Clock
1279 MHz
CUDA Cores
2048
Dual Slot Fan Cooler, Dual Fan Design, Super Alloy Power technology, ASUS DIGI+ VRM, GPU Tweak Streaming, ASUS DirectCU II with 0dB Fan Technology, HDCP
Size
4 GB
GDDR5 SDRAM
Effective Clock Speed
7.01 GHz
Bus Width
256-bit
Additional Requirements
6-pin + 8-pin power connectors
300 Watt
Software Included
Driver, ASUS GPU Tweak
4.09 cm
28.86 cm
13.44 cm
Limited warranty - parts and labour - 3 years
9TRR C2G 2m Value Series™ High Speed HDMI® with Ethernet In Stock £8.33
