ASUS GTX 950 is an astonishing graphics card - with distinctive white coloring. Featuring a dual fan cooling technology, ASUS GTX 950 delivers 2X greater airflow and 3X quieter performance. It also comes equipped with AUTO-EXTREME technology and Super Alloy Power II for premium quality and best reliability. With 14-days free premium license of customized ASUS GPU Tweak II and XSplit Gamecaster utility, ASUS GTX 950 enables you to squeeze every last drop of performance and lets you stream or record your gameplay instantly. It also comes with a World of Warships invite code for a free 15-day premium account and an exclusive Diana Cruiser. Claim your code and win some battles!
ASUS GTX 950 graphics card and Z170 motherboards share perfectly matching color themes and are ready for Windows 10. GTX 950 is equipped with DirectX 12 to squeeze more graphics performance from the CPU and prevent GPU bottlenecks.
Twin optimized fans carefully selected by engineers drive 2X greater airflow while maintaining 3X quieter performance, combining enhanced cooling with a more pleasant gaming and computing environment.
Be unique, stand out from the crowd
ASUS GTX 950 is an astonishing graphics card - with distinctive white coloring. Featuring a dual fan cooling technology, ASUS GTX 950 delivers 2X greater airflow and 3X quieter performance. It also comes equipped with AUTO-EXTREME technology and Super Alloy Power II for premium quality and best reliability. With 14-days free premium license of customized ASUS GPU Tweak II and XSplit Gamecaster utility, ASUS GTX 950 enables you to squeeze every last drop of performance and lets you stream or record your gameplay instantly. It also comes with a World of Warships invite code for a free 15-day premium account and an exclusive Diana Cruiser. Claim your code and win some battles! -
Perfectly matched with ASUS Z170 motherboards
ASUS GTX 950 graphics card and Z170 motherboards share perfectly matching color themes and are ready for Windows 10. GTX 950 is equipped with DirectX 12 to squeeze more graphics performance from the CPU and prevent GPU bottlenecks. -
Dual fan cooling
Twin optimized fans carefully selected by engineers drive 2X greater airflow while maintaining 3X quieter performance, combining enhanced cooling with a more pleasant gaming and computing environment. -
AUTO-EXTREME technology with Super Alloy Power II
ASUS graphics cards are produced using AUTO-EXTREME technology, an industry-first 100% automated production process, and feature premium Super Alloy Power II components that enhance efficiency, reduce power loss, decrease component buzzing under load, and lower thermal temperatures for unsurpassed quality and reliability.
- ASUS GTX950-2G - graphics card - GF GTX 950 - 2 GB
- Graphics card
- Bus Type
- PCI Express 3.0 x16
- Graphics Engine
- NVIDIA GeForce GTX 950
- Memory
- 2 GB GDDR5
- Core Clock
- 1051 MHz
- Boost Clock
- 1228 MHz
- CUDA Cores
- 768
- Effective Memory Clock
- 6.61 GHz
- Memory Interface
- 128-bit
- Max Resolution
- 4096 x 2160
- Interfaces Details
- DVI-I , DisplayPort , HDMI
- API Supported
- OpenGL 4.5
- 4 cm x 21 cm x 11.3 cm
- Graphics card
- Bus Type
- Graphics Engine
- Core Clock
- 1051 MHz
- Boost Clock
- 1228 MHz
- CUDA Cores
- 768
- Max Resolution
- 4096 x 2160
- API Supported
- OpenGL 4.5
- Native HDMI, Nvidia PhysX-Ready, Nvidia 3D Vision Surround Ready, Dual Fan Design, Nvidia SLI ready, NVIDIA Adaptive Vertical Sync, NVIDIA GPU Boost 2.0, NVIDIA G-Sync ready, Super Alloy Power II technology, AUTO-EXTREME technology, HDCP
- Size
- 2 GB
- Technology
- GDDR5 SDRAM
- Effective Clock Speed
- 6.61 GHz
- Bus Width
- 128-bit
- 75 Watt
- Software Included
- Display drivers, ASUS GPU Tweak II, World of Warships invite code, XSplit Gamecaster (14 days Premium licence)
- 4 cm
- 21 cm
- 11.3 cm
